Update - NP231 Swap - Page 2 - JeepForum.com
post #16 of 31 Old 06-12-2013, 09:21 PM
shackwrrr
Why was the driveshaft shortened? Internal to external slip yoke?
shackwrrr is offline
post #17 of 31 Old 06-12-2013, 09:55 PM
RoldGold
Originally Posted by 98ZJLTD View Post
Nice, sounds like It should be easier than I was thinking it was gonna be then. Did you change the plugs for the 4wd indicator on the vic? I can't decide if its worth the effort or not, my vic works fine (for now) and I kinda like having it but if I can manage to get my hands on 2wd cubby I might just go that route instead. I will definitely hit you up if I need anymore details, I'm feeling pretty solid about it at this point t though.
I don't mean to bomb your thread but I just PM'ed you there buddy.
RoldGold is offline
post #18 of 31 Old 06-13-2013, 07:58 AM Thread Starter
huntsducks70
the 249 i took out was internal slip, the 231 from the xj was external. i removed an inch, this allows exactly one inch of slip before the shaft runs into the tcase, hope it is enough?
huntsducks70 is offline
post #19 of 31 Old 06-13-2013, 08:57 AM
PolkaPower
When the axle droops the drive shaft compresses and extends when it's horizontal so with the extra fat chicks you should be fine.
PolkaPower is offline
post #20 of 31 Old 06-13-2013, 09:56 AM Thread Starter
huntsducks70
damn, what's up with you and fat chicks, did you get dumped by one and now you have a vendetta against them? not very nice either way, they have feeling too, try to be nice to them
how high can i go with my stock driveshaft? is 5.5" reasonable?
post #21 of 31 Old 06-13-2013, 09:59 AM
PolkaPower
I never said anything negative about fat chicks. The ZJ drive shafts are very long. There are plenty of folks on here taller than that with stock shafts.
post #22 of 31 Old 06-13-2013, 10:00 AM
WhiteOut
WhiteOut's Avatar
Do you have the CV or u-joint type in the front? CV type will eat itself at about 3" of lift, u-joint type should be ok.
The rear isn't going to be an issue, I'm just under 6" and still with the stock shaft.
WhiteOut is offline
post #23 of 31 Old 06-13-2013, 10:24 AM
98ZJLTD
I will be going from an ISY to an ESY when I swap my 231 in as well, however I'm also going to be lifting it 4.5 inches at the same time I do the t case swap. From what you guys just said, it sounds like I will still need to shorten my DS since I could go over 6 before I would have to possibly get it lengthened. Am I understanding that correctly, or is there a chance I may not have to shorten it since I will be lifting as well?
98 ZJ Limited- NP231 swap, IRO 4.5 inch Springs, Hydro Shocks, IRO adjustable double shear track bar, JKS quick discos 33x12.50 Kumho Road Venture MT on 15x8 D windows with 3.75 inch BS
My build thread-
98ZJLTD is offline
post #24 of 31 Old 06-13-2013, 10:46 AM Thread Starter
huntsducks70
thanks, good to know.
post #25 of 31 Old 06-13-2013, 10:51 AM Thread Starter
huntsducks70
i have the double carden (u-joint) front shaft, so i should not have an issue at 5.5"?
thanks for the confirmation on the rear shaft, it is appreciated
post #26 of 31 Old 06-13-2013, 10:54 AM Thread Starter
huntsducks70
i would definitely check the fit before committing to shortening the shaft, you may not need to do it, good luck Sir!
post #27 of 31 Old 06-13-2013, 10:54 AM
dnuccio
thats on the transfer case end. Some of them had a cv joint at the axle
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #28 of 31 Old 06-13-2013, 11:38 AM Thread Starter
huntsducks70
got it, yes, it is a u-joint at the axle as well, thanks for the heads up.
post #29 of 31 Old 06-13-2013, 12:50 PM
dnuccio
should be fine then with the u joint at the axle. Im at 2 inches and I had a cv and it blow up not even wheeling I was driving up onto car ramps to change my oil lol
R.I.P. Ratmonkey
dnuccio is offline
post #30 of 31 Old 06-13-2013, 01:36 PM Thread Starter
huntsducks70
wow, that's crazy. i am guessing you now have a u-joint at the axle.
