#1 | |
Update: Coolant issue
So I started the thread below for assistance w/a coolant issue.
http://www.jeepforum.com/forum/f13/help-me-diagnose-coolant-issue-long-365721/ This is a quick synopsis. I've changed the water pump/thermostat/radiator and various hoses because of the leaks I had. Last night, I finished up installing the radiator and I burped the system. I let it run for 20-30 mins then I took it out for another 20-30 min drive. The heat was working fine, everything was perfect!!! I get up this morning to run an errand and I start it up and the "Coolant Low" light was on. I open the hood and the overflow tank was at the low mark. My first thought is OK...the radiator just needed that extra coolant because I didn't burp it long enough. ![]() I go out this afternoon and fill the coolant overflow and start it up. After 10 mins, I can see bubbles rising in the over flow tank. Just a small bubble every couple of secs. There are still no visible leaks. The oil and tranny fluid both look OK. Neither look like they have water in them. I guess my next step is to 'borrow' a pressure tester from Autozone's 'Loan-a-tool' program that they have. Are there any other suggestions? There is a coolant smell on the outside of the rig, but the exhaust isn't white and fluffy and there is zero trace of it when you are in the cab, heat on or off. I'm completely perplexed. ![]()
--Nick My Ride: 1998 GC Limited Colorado Jeep Club Member #15 Black Jeep Club Member #1976 Make the world a better place, punch a Boilermaker in the face!!! Don't blame me...I didn't vote for him. |
#2 |
is there a puddle on the ground?
I have a modified 1999 WJ and a stock 2001 WJ Tread Lightly Pictures PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! ! |
#3 | |
#4 |
Whats the concern then?
Upon first starting I can see a bubble every now and then in the over flow tank.. Probably just didnt give it time to circulate the coolant and just needed to top it off the next day.
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires Last edited by -Joe-; 02-03-2007 at 04:45 PM.. |
#5 |
Make sure your hose clamps are fully seated and tightened properly. About a month back I changed the hoses and had the smell but no ground puddles. Every few days, the bottle was low. I knew it was the lower hose because I saw it seeping, got under it and tightened the clamp a little more for the cure.
You can't get an external smell without some type of leak. Good Luck.
'00 GC Laredo 4.7 / FM Delta Flow 40 Series / K&N Drop in /Rancho 5000's and Steering Stabilizer / Uniden 68LTW CB w/4' FS II |
#6 |
Just replace the radiator cap. It is probably bad and relieving the pressure at a lower pressure than it was designed to. It should be a something like a 16 psi cap. The engine can also over-heat with a bad cap. The 16 lb pressure raises the boiling point of the solution (coolant). This is usually evident by an overflow reservoir that is always filled up to the brim.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#7 |
If you have access to a pressure tester, throw it on the Jeep when cold and let it sit @ 18lbs for quite a while to see if any leaks.
As you just did the water pump, make certain you retightened the hose clamps when the Jeep is hot, and the hoses are more pliable. |
#8 |
Ok here's what's up. It appears that the new gasket isn't holding in the coolant on the bottom of the water pump and that's where the leak is stemming from.
I plan on replacing the gasket this weekend. Is it possible to use a gasket other then the paper one that is supplied w/the water pump? What about RTV or Hondabond? I am skittish to use these type of sealants w/the fear that they might clog the heater core. Thoughts?
#9 |
I use Indian Head Cement... at least the gasket wont slip
94 Grand Cherokee ... 332,000 miles 5.2 liter 242 :) Rancho 5000 steering stabilizer |
#10 |
OK this is what I do with all water pumps. The two mating surfaces have to be parallel!! Take as much time as necessary to accomplish this. After scraping and such, I use a gasoline soaked sponge with Scotch-brite (the green scratchy stuff) to remove any residual paper or silicone remnants.
Then I coat both sides of the paper gasket with Permatex sealant. I only use the type made for water pumps. It’s in a gray tube. Then I use a torque wrench. The torque is 30 ft-lbs for the v8 engines made between 1993 to 1996. This is important. I sometimes even torque it twice (like first at 20 ft-lbs and then again to 30 ft-lbs). Tighten them in a star-like fashion (similar to the pattern of torqueing the lugs nuts on a wheel) Let it sit for a couple of hours, if you can, before filling with coolant. These guidelines should help minimize post-leaks.
#11 | |
#12 |
Thanks again for the tips guys!!!!! I will let you know the outcome when I do it this weekend. Thanks again!!!!
#13 | |
#14 |
I havealways used permatex high-tack on paper gaskets. With clean mating surfaces as mentioned above have never had a leak.
You can brush it on and let it sit a minute to adhere so it doesn't move when installing. Good luck... |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
