Quantcast UPDATE on ARB Snorkel for pre-96 ZJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > UPDATE on ARB Snorkel for pre-96 ZJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSALE PRICING, Specials, Huge Savings Alloy USA and Posi-LoGR8TOPS Introduces the Exogate HD Tire Carrier
Old 02-09-2008, 12:41 AM   #1
CLNinja
this is the email i just got from ARB
SS1120HF Snorkel fitment to pre 1996 Jeep Grand Cherokee 4.0l/5.2L
The SS1120HF snorkel is designed to bolt into a 1996-1998 Jeep Grand Cherokee vehicle. This snorkel can be fitted to an earlier model with some additional modifications during the installation.
Overview: 1993-1995 model year trucks have the anti lock brake (ABS) controller mounted next to the factory airbox on the inner fenderwell. This conflicts with the routing of the air inlet from the Safari Snorkel SS1120HF kit. Further, the early model vehicles do not have an opening in the fenderwell also used in the Safari kit as the later vehicles do.
Fitting the snorkel is possible, but requires relocating the ABS controller and cutting an opening for the inlet plumbing into the inner fenderwell. The following steps show how we have done these modifications (this is only a guide). The only drawback is that the ABS controller has been relocated into an area somewhat more vulnerable which may be a concern for some installers. In that circumstance it may be necessary to lengthen the harness and find a different spot to place the ABS module. We simply found the simplest way to accomplish the installation with the least vehicle modification required. Use your own discretion as ARBUSA will not be responsible for damaged controllers resulting from the relocation.
These instructions supplement the Safari instructions and need to be done prior to installing the snorkel body and components.
1. Remove the factory airbox.
2. Unbolt the ABS controller and set the hardware aside, it will be reused later.
3. Route the harness through the hole in the sheet metal directly below the air box mount.
4. Remove the inner fenderwell and set it aside. Removal of the wheel is optional, but makes the job easier.
5. Place the ABS controller against the vertical sheet metal located in front of the wheel and mark the position of the bracket mounting holes. The controller is being remounted behind the inner fenderwell towards the front of the vehicle.
6. Drill the three holes previously marked for the bracket to the appropriate size for the O.E. hardware.
7. Reconnect the harness and mount the ABS controller.
8. Install the airbox adapter supplied in the Safari kit onto the factory airbox per the Safari instructions.
9. Place the airbox assembly, now modified and fitted with the inlet adaptor into its original mounting location.
10. With the airbox in place mark the area of the inner fenderwell using the air filter adapter as a rough guide.
11. Using a holesaw (the size required for the exterior snorkel hole for the fender works fine) drill the necessary hole in the inner fenderwell. Touch up the bare sheet metal with a file and paint as needed to avoid corrosion.
12. Install the remaining Snorkel components per the Safari instructions.
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Old 04-18-2008, 11:41 PM   #2
Tdoggnasty
1994 ZJ
Just got my Snorkel and installed it per these relocation instructions, worked great... Thanks for posting!
Tdoggnasty is offline   Reply With Quote
Old 04-19-2008, 12:01 AM   #3
Darthteddy
1955 M-38
Whered u order it from and how much did it run you??
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline   Reply With Quote
Old 04-20-2008, 03:44 AM   #4
Tdoggnasty
1994 ZJ
I got mine off of EBay... CSL Off-Road I believe... I had water over the hood over the weekend and was glad I had had it... Not all of us can rock crawl without a stream in sight but some of us need some insurance... Not cheap, around $479 shipped. I believe www.kevinsoffroad.com also has it in stock for a little cheaper. Works fine on a 5.2 with a little fabricating, which I have none of. FYI, anyone need a 5" hole saw let me know, Home Depot won't let me return it
Old 04-20-2008, 09:45 AM   #5
Darthteddy
1955 M-38
Im savin up for one. Its in line right behind the lift. Which is right behind gettin my jeep RUNNING again. haha. I might take you up on the holesaw tho sometime.
Old 04-20-2008, 11:04 AM   #6
CLNinja
if Anyone Wants The Original Email Forwarded To Them Which Includes Pictures For Each Step Please Pm Me
Or Can A Mod Please Pm Me With There Email So I Can Send It To Them And They Can Put It In The Faq?
Old 04-20-2008, 06:25 PM   #7
Tdoggnasty
1994 ZJ
Oooooh... I wish I would have known there were pics available... That would have helped. Perhaps I should have asked. Here is a video I made after promptly getting it stuck after I wanted to go try out the snorkel. There are a few pics and short video. The snorkel looks pretty cool. Could you go ahead and forward the email anyway, just to see how I did compared to them
http://www.youtube.com/watch?v=_uQo2c-62KI
Old 04-20-2008, 08:36 PM   #8
Virmagicus
Headed Out West
Virmagicus's Avatar
Haha pretty funny actually. Cool tune.
[YT]_uQo2c-62KI[/YT]
Virmagicus is offline   Reply With Quote
Old 04-20-2008, 09:02 PM   #9
UltimatE
Resident Audio Guru
UltimatE's Avatar
Disturbed - The game... good song.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Old 04-21-2008, 07:08 AM   #10
madrabbitt
that vid rocked... lol
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 04-26-2009, 01:38 PM   #11
hockinaloogie
Snorkle
Does anyone have a under the hood pic of a 4.0 with a safari snorkle on it? I am wanting to buy one and want to know how much fab work is needed to get it to fit the 5.2. Also I have been trying to get in touch with the people from Roca Silva but I dont speak that. Anyone else have any luck or have a snorkle for sale email me.
hockingloogie@hotmail.com
Roca Silva: http://www.rocasilva.com/snorkel/snorkel.html
hockinaloogie is offline   Reply With Quote
Glock Forum
