Up, up, up. Going to 5" soon, few Q's - Page 2 - JeepForum.com
post #16 of 20 Old 11-05-2009, 12:16 AM
Jones
Consider the following...
Jones's Avatar
Originally Posted by Fraser_Brown View Post
Cherokee HP30 in the front with 4:10 and D44a out of a 96+ ZJ in the rear? I'll need a bracket kit for the HP30 right?
Might as well go 4.56 so you don't have to regear twice, I'd also look at locking the rear axle while you're in there. The HP30 is a bolt in swap, XJ's, ZJ's, and TJ's all have the same front suspension. Try to find a 96-99 HP30 because they have the stronger u-joints. Make sure it's at least 93-99 to avoid the vac disco housing.
Jones is offline
post #17 of 20 Old 11-05-2009, 12:18 AM Thread Starter
WhiteOut
WhiteOut's Avatar
I'm stopping at 5" and 33's so i think 4:10 will be fine with the V8
WhiteOut is offline
post #18 of 20 Old 11-05-2009, 12:21 AM
Jones
Jones's Avatar
Are you sure you're stopping there? I thought I was stopping there too.
Jones is offline
post #19 of 20 Old 11-05-2009, 12:22 AM Thread Starter
WhiteOut
WhiteOut's Avatar
Yeah, the only upgrade after that might be front LA's down the road. Did any of the HP30's come stock with 4:10s?
WhiteOut is offline
post #20 of 20 Old 11-05-2009, 01:39 AM
indredsnake99
taken from the xj tech forum
3.07 - used with 4.0L engine / manual transmission
3.31 - only available on older (pre87?) 2 door XJs with "Fuel Economy" package
3.55 - used with 4.0L engine / automatic transmission
3.73 - found in some XJs with the towing package
4.10 - used with 2.5L engine usually, and older XJs with the "Off-Highway Vehicle" package.
4.56 - rare but can be found on some older (~ 89 ~) models with 2.5L engine and auto transmission
Wayne
1997 formerly GREEN now rustoleum bed lined zj 4.0 np242 bought 9/25/2008
gone
1998 5.9l platnium zj np249 k&n sct bought 4/6/2010
2007 sahara 2 door wrangler stock bought 02/08/2011
You'll learn a lot. I didn't know anything when I first joined this site either. (not sure if that's changed at all :laugh:)
indredsnake99 is offline
"xenon" or "true white" headlight bulbs .. exist? sanboy ZJ Grand Cherokee Forum 16 10-12-2010 09:23 PM
Front Calipers "Teves" or "Akebono"? jimmy328 ZJ Grand Cherokee Forum 10 07-25-2009 09:48 PM
"Grand Cherokee" and "Limited" emblems? jdwiseman ZJ Grand Cherokee Forum 14 02-04-2009 06:49 PM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 06:06 PM
Chirping/Squeaking only when in "Park" or "N" 3D-Dave ZJ Grand Cherokee Forum 1 05-01-2004 03:05 PM
