Unstable Swaying at highway speeds - Page 2 - JeepForum.com
post #16 of 22 Old 05-08-2012, 03:26 PM
PolkaPower
Since pinion angle takes precedence over castor, I would think that if you had way to much positive castor that you would be getting some really bad driveline vibes front the front. Just get under there and make sure that the front diff is pointed straight at the t case input. My swaying on the highway issue was from worn out control arm bushings.
PolkaPower is online now
post #17 of 22 Old 05-08-2012, 05:41 PM
PaYj
I do have bad vibes. I orders adjustable control arms as mine are fixed. When u say worn was there a lot of movement like a clunk or just soft
78 J10 360 V8
88 Yj 305 V8 SOA
96 Zj 3.5
PaYj is offline
post #18 of 22 Old 05-08-2012, 05:48 PM
MarkInTombstone
How many plies are the tires and what's your tire pressure set at? That will change everything to what the door says.
You'd be doing me a favor if you called me Mark or Tombstone, but not both.
MarkInTombstone is offline
post #19 of 22 Old 05-08-2012, 06:03 PM
PolkaPower
These were the originals when I bought it. 128,000 miles on a stock ZJ. Wandered all over the road. And felt like I had no shocks in the turns.
post #20 of 22 Old 05-09-2012, 03:43 AM
PaYj
Plies not sure they are general grabber at2. 30 psi. Same tires were on wrangler with zero problems. I will replace front control arms today and get rear bushings and see how it works out
78 J10 360 V8
88 Yj 305 V8 SOA
96 Zj 3.5
PaYj is offline
post #21 of 22 Old 05-09-2012, 08:33 PM
MurdaJs
did you check your track bars
MurdaJs is offline
post #22 of 22 Old 05-11-2012, 01:52 PM
PaYj
Yes, I just installed my new adjustable lower arms set my caster to 6.5 degrees and it helped a lot. It's drive able now but still sways a little bit. I am going to order adjustable uppers and new rear bushings to see if it will go away completely
78 J10 360 V8
88 Yj 305 V8 SOA
96 Zj 3.5
PaYj is offline
alignment , bolt , sway , Tie rod end , track bar
WJ: Loud hum at highway speeds W3MOT WJ Grand Cherokee Forum 10 12-19-2010 12:40 PM
95 5.2 spits and sputters at highway speeds spikeystrip ZJ Grand Cherokee Forum 1 03-17-2010 09:33 AM
Vibration at highway speeds droldsw32 ZJ Grand Cherokee Forum 0 11-15-2009 12:53 PM
5.9 dies only at highway speeds. . . help!! pricer5.9 ZJ Grand Cherokee Forum 2 01-18-2009 10:20 PM
Rumble/vibration at highway speeds Little Black ZJ ZJ Grand Cherokee Forum 4 09-09-2007 04:18 PM
