Under hood light switch?? - JeepForum.com
post #1 of 6 Old 01-24-2013, 04:27 PM Thread Starter
kb9mfd
I know this is just a small convenience, but I tried to replace the hood light and found the hard way it does not turn off. Probably why it did not have one. After draining my battery over night, what is suppose to shut it off? I cannot find a switch or tilt switch anywhere and the wire just disappears into the wiring harness. Thanks! - Jeremy
kb9mfd is offline
post #2 of 6 Old 01-24-2013, 04:36 PM
kg6mov
Hears the voices
kg6mov's Avatar
If nobody pops up before then I'll have a look at the wiring diagrams in the FSM when I get home.
kg6mov is offline
post #3 of 6 Old 01-24-2013, 04:37 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Believe it has a mercury switch in it but not sure.
Originally Posted by HighLonesome
coralman is offline
post #4 of 6 Old 01-24-2013, 04:53 PM
SAR-Swimmer
Coralman is correct, there is a mercury switch, right in the lamp socket assembly, it'self.
@ kb9mfd, just splice in a switch before the lamp, and you should be able to use the setup you installed. I'd be tempted to mount switch in engine compartment, just to remind myself to turn it off when finished with it.
SAR-Swimmer is offline
post #5 of 6 Old 01-24-2013, 06:06 PM
G-Man2
If I remember correctly my 96zj has mercury switch in socket assembly and it controls the ground side of the light. The 12v side is always hot.
G-Man2 is offline
post #6 of 6 Old 01-24-2013, 08:45 PM
KoreaZJ
1994 ZJ
Switch is in the base. Grab one from JY.
KoreaZJ is offline
hood light , lights
