unbolting a heavy duty hitch - JeepForum.com
post #1 of 5 Old 07-21-2009, 06:48 AM Thread Starter
kbjaeger
My problem is that some of the bolts are just turning round.
if I can remove the rear bumper do I in any way get acces to
the top of the bolts so I can counteract the spinning?
The hitch is rusty so I want it to be sandblasted and painted.
Thanks
kbjaeger is offline
post #2 of 5 Old 07-21-2009, 06:59 AM
Coletrickle
You might as well cut the heads off with a torch or cut off wheel. The "frame rails" of the unit body were tapped in my ZJ, I assume they are all that way. I doubt if you'll be able to get access, and it probably won't do any good anyway.
93 Grand Wagoneer
5.5" Hybrid Lift/BDS CA's
231/skids/33" KM2's
Homegrown Bumper
Aussie
Coletrickle is offline
post #3 of 5 Old 07-21-2009, 07:30 AM Thread Starter
kbjaeger
I thought of that too, but then I will not be able to reinstall?
kbjaeger is offline
post #4 of 5 Old 07-21-2009, 08:42 AM
Bort62
On my '98, The factory bumper mounted w/ nut plates that were secured through the hitch / skid on the bottom via studs.
The studs have a retaining feature that kinda keeps them from coming out even when the threads are off.
If you get all 4 nuts off + the two bolts in the back (front?) you should be able to kinda shake rattle & roll the thing until the studs fall out and then it just falls off.
The nuts won't always back all the way off the studs.
___________
'98 Grand
'60 Ranchero
Bort62 is offline
post #5 of 5 Old 07-21-2009, 11:48 AM Thread Starter
kbjaeger
Thanks for the answers.
Maybee I just sandblast- and paint it still attached to the frame together with the axle.
Thanks for the replies.
KIm Jaeger
In 1969 I spent my year at Laredo AFB. OUTSTANDING YEAR
kbjaeger is offline
heavy duty bumpers ... phitmein ZJ Grand Cherokee Forum 2 03-24-2009 10:59 PM
OME medium or heavy duty? drespecki ZJ Grand Cherokee Forum 5 12-03-2008 08:35 AM
Heavy Duty 42re lucky_logger6 ZJ Grand Cherokee Forum 7 08-31-2007 07:27 AM
Heavy Duty Tie-Rods. Death-Mobile ZJ Grand Cherokee Forum 3 10-31-2004 08:34 PM
Heavy Duty Cooling??? Tmaxx ZJ Grand Cherokee Forum 4 07-16-2003 04:38 PM
