-   -   unbolting a heavy duty hitch (http://www.jeepforum.com/forum/f13/unbolting-heavy-duty-hitch-821186/)
kbjaeger 07-21-2009 05:48 AM
My problem is that some of the bolts are just turning round.
if I can remove the rear bumper do I in any way get acces to
the top of the bolts so I can counteract the spinning?
The hitch is rusty so I want it to be sandblasted and painted.
Thanks
Coletrickle 07-21-2009 05:59 AM
You might as well cut the heads off with a torch or cut off wheel. The "frame rails" of the unit body were tapped in my ZJ, I assume they are all that way. I doubt if you'll be able to get access, and it probably won't do any good anyway.
kbjaeger 07-21-2009 06:30 AM
I thought of that too, but then I will not be able to reinstall?
Bort62 07-21-2009 07:42 AM
On my '98, The factory bumper mounted w/ nut plates that were secured through the hitch / skid on the bottom via studs.
The studs have a retaining feature that kinda keeps them from coming out even when the threads are off.
If you get all 4 nuts off + the two bolts in the back (front?) you should be able to kinda shake rattle & roll the thing until the studs fall out and then it just falls off.
The nuts won't always back all the way off the studs.
kbjaeger 07-21-2009 10:48 AM
Thanks for the answers.
Maybee I just sandblast- and paint it still attached to the frame together with the axle.
Thanks for the replies.
KIm Jaeger
In 1969 I spent my year at Laredo AFB. OUTSTANDING YEAR
The time now is 12:39 PM.
