Quantcast unbelivable bolt on tie rod side of steering stablizer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > unbelivable bolt on tie rod side of steering stablizer
Old 11-20-2009, 02:05 PM   #1
am9010
i need every tip and trick known to jeep owners on how to take out the bolt connecting the steering stabilizer to the tie rod, ive already mushroom the bolt, destroyed threads by bashing it with a nut on, pitarm puller hasnt worked, ive torched the hell out of it, pb, pryed, im about to grind it down and drill threw it but the guys at ironrockoffroad dont suggest i do that.
am9010 is offline   Reply With Quote
Old 11-20-2009, 02:17 PM   #2
Apollo21
tried a bolt splitter yet?
Patrick- MIDN 2/C USMS (USN)
Skipper of [I]SIRINA[/I] 1969 31' Bertram
2002 Red Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, sweet headlights, rear addco, spring retainers, KOR SS, liftgate light, Alpine/Polk speakers, and power inverter with USB.
Build thread [url]http://www.jeepforum.com/forum/f22/apollo21-build-thread-902929/[/url]
[QUOTE=Jerry Bransford;11691320]Worrying too much about mpg with a Jeep is similar to worrying about your sister's virginity. An ok thing to be concerned about but...[/QUOTE]
Apollo21 is offline   Reply With Quote
Old 11-20-2009, 02:39 PM   #3
JrMechanic
Transfer Case Guru
JrMechanic's Avatar
Just leave it in.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
http://www.jeepforum.com/forum/f13/np249-np231-np242-swap-information-updated-685644/
JrMechanic is offline   Reply With Quote
Old 11-20-2009, 05:22 PM   #4
2tone93zj
yea it took me a long time to get that sucker out. You have to have a GOOD pitman arm puller with thick arms and heavy casting so it wont bend. Since u've mushroomed the bolt you have to cut off the end so that it will slide through the hole. So get a pitman arm puller like this:
http://getmetools.com/pics/li41970.jpg
Tighten it as tight as you can to the bolt with a breaker bar, then heat around the bolt with MAP gas or something hotter propane wont do it. heat it till the threads are glowing red then start tightening the pitman arm puller again it starts to get scary as there is so much force on that puller than something has to give and then BOOM wala the SS hits the oil pan and can leave a dent. So make sure you have some sort of protection for your face and the oil pan.
Good luck
1993 Jeep Grand Cherokee Laredo
I-6, 42re, 249-->242 selec-trac swap, D30/D35
31x10.5, 3.5" IRO F>R, skids and tow hooks
Wanted: 93-95 Keyless entry fob
BUILT NOT BOUGHT #204
2tone93zj is offline   Reply With Quote
Old 11-20-2009, 05:46 PM   #5
Kramer H
Built and Supercharged 47
Kramer H's Avatar
torch it off? cutting torch has gotten me out of many tight jams.
Built Beater 01 WJ MY BUILD THREAD
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Jardine,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, B&N
Kramer H is offline   Reply With Quote
Old 11-20-2009, 08:32 PM   #6
indianajeep
indianajeep's Avatar
2005 WK
I did this same job last night. I heated up the tie rod around the bolt for 10 minutes with a propane torch. Then I hit the end of the bolt 5 times on the end with a 4 pound hammer. I was lying on the ground under the passenger side and hitting it dead on. After the fifth hit it popped right out. Be careful not to heat up the bolt. It just makes it expand more in the the tie rod hole.
indianajeep is offline   Reply With Quote
Old 11-20-2009, 10:50 PM   #7
JrMechanic
Transfer Case Guru
JrMechanic's Avatar
Good luck
This is NOT the proper way to use a puller. DO NOT DO THIS! You run the risk of breaking things, mainly the puller. That much force sending exploding chunks of metal is not good. The "proper" way to use a puller is to apply pressure to the bolt and tap it with a hammer. The puller itself is not meant to drive the bolt out.
Again, if it's mushroomed and not coming out unless you cut it out, just leave it in. The bolt is only for the steering stabilizer, it sees very little load, and if it were to fail, it isn't a safety concern. I ran mine like that for 6 months.
Old 11-21-2009, 10:11 AM   #8
baxy
I usually rattle the side of the tapered bolt with an air hammer with a flat chisel installed in the hammer
pops right out
baxy is offline   Reply With Quote
Old 11-21-2009, 10:17 AM   #9
redhatman
When I installed my IRO Steering setup and replaced my stabilizer, how did I get that off? Oh yeah, I didnt I just left it on. They are a real pain in the a** man, but I would suggest heat and pb blaster. Just be careful with an open flame around the shock. They can explode.
-Pat I'm 19, and getting my hands cut while learning
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
Looking for quality Jeep parts? www.ironrockoffroad.com
redhatman is offline   Reply With Quote
Old 11-21-2009, 11:53 AM   #10
indianajeep
2005 WK
I'm curious, did you get out the bolt, yet?
Old 11-21-2009, 11:54 AM   #11
Mark4883
I hate these things with a passion.
Mark4883 is offline   Reply With Quote
Old 11-25-2009, 09:52 AM   #12
am9010
yeah i got it out, i grinded that bolt flush with the tie rod bought a really small pitman arm puller so it wouldnt slip off under pressure, cranked it with a 4 foot breaker bar, bashed it with a 5 lb hammer when that ****er came off i thought it went through my engine block sounded like someone shot an SKS 3 feet from me HAHA
Old 11-25-2009, 10:07 AM   #13
Apollo21
what's wrong with a bolt splitter?
Old 11-25-2009, 11:59 AM   #14
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
What's a "bolt splitter"? Do you mean a "nut splitter"? He already had the nut off. The tapered stud was stuck in the tie rod end's tapered hole.
-Steve
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline   Reply With Quote
Old 11-25-2009, 01:10 PM   #15
Apollo21
oh my mistake
Glock Forum
