Quantcast The Ultimate Roof Rack Wiring Guide - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > The Ultimate Roof Rack Wiring Guide
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 05-15-2007, 12:45 AM   #1
th3godf4th3r
Hey everyone,
Well I've seen alot of thread showing how people wired their lights on their roof racks. Some chose the hole through the roof method, some chose down the door method and some chose down the lift gate method.
Personally I couldnt stand the thought of drilling a hole through my roof and then accidently screwing up, although it would look very clean which I like. I also thought that having a bulk of wires running down my drivers door wouldn't look good either.
So I went with the lift gate method.
This is my guide for you guys being such a big help to me. This install is not extremely difficult but if you get frustrated easily, this install may not be for you.
Here we go.
1)Tools & Supplies needed:10mm Socket wrench
13mm Socket wrench
13/16 socket wrench
Standard Philips Screwdriver
Wire stripper & crimper
Electrical tape
Zip ties
Wire loom tubing
16 guage butt splices (or whatever size your using)
150 feet 16 guage wire (or whatever size your using
2) First disconnect the negative wire from your battery
3) Mount your roof rack on your car (if its not already) and then mount your fog or driving lights to your mount that attaches to your rack.
4) Strip about 1/4th of the wire off from your positive and negative wires coming from your lights and your 18 guage wire. Using the butt splices connect +/+, -/- (duh) Next, roll out about 20-25 feet of wire then cut it. Do this however many lights you have, i.e I had 4 lights so i needed 8 butt splices and 100 feet of wire.
5) Now for the disassemly. Start by opening your lift gate and removing the 4 screws around where the door locks.(pic coming) Then remove 1 screw on the left of the ceiling holding the vent in place. Next remove your spare tire (if you have one) unscrew 2 screws near the left side rear seat belt
Once all screws are out remove panel above the rear lift gate shock (pic coming)by simply pulling on it and it will pop out. Next, move to the left rear door and using a 13/16 socket wrench unscrew the bolt that holds the seat belt in place
Then remove panel around the seat belt slider, which in the picture above is right behind it. Use the same method as the last panel, pull and pop.
Once you get the panel off there will be a screw, which you need to take out.
Now right in the middle of the plastic foot panel inside the car there is a screw which also needs to be taken out.
You can now take off the entire panel that covers the left rear tire
6) Now that you have that off, next remove vent on the outside of the car.
There will be a small hole already there, which you can use to run the wire through.
7) Finish wiring and zip tying up the roof rack and cover the wires with wire loom tubing
8) Start to one by one push your wires into that hole and by reaching up through this part
you can grab hold of the wires and string them through. Once all wires are strung through, leave a little slack on the outside for some adjusting.
9) Next start to run your wires through this
Then start wiring them like this
10) Now it is time to remove the rear passenger seat and using you 10mm socket wrench remove the bracket that hold the seat in place (pic coming)
th3godf4th3r is offline   Reply With Quote
Old 05-15-2007, 12:47 AM   #2
th3godf4th3r
11) Next remove the drivers seat by unscrewing the 4 bolts holding them down the your 13mm socket wrench, there are 2 screws in the front, 2 in back
After you unscrew them, push the entire seat back and you will see a wire connecting to your seat. Push the red slider to the right
Then pull the harness out and take the seat out of the car.
12) Time to remove all plastic foot paneling. First start by taking out the 3 screws by the drivers side left foot panel
next remove 3 screws in foot panel (pictures starting from front to back)
Then using your 13/16 socket wrench remove seat belt bolt on the floor
Old 05-15-2007, 12:48 AM   #3
th3godf4th3r
Next move up and still using your 13/16 wrench remove upper seat belt bolt like you did for the rear
Then remove panel like the rear
After you remove the panel there will be two screws mid way up the pillar, remove them
You can now take the entire foot panel off and get back to your wiring
13) Continue your wiring down to underneath the carpet. Follow the pictures as a guide
You can remove 3 screws from this plastic wire holder
And run your wires in with the others. They will then pop out right here
14) Unless you have done other previous wiring, you will need to make a bigger opening in your firewall. I did not have to do this but if you have to but a 1" circle cutter that goes on a drill and make a hole.
15) Run your wires through your fire wall
and out into the engine compartment
Old 05-15-2007, 12:49 AM   #4
th3godf4th3r
16) Run them over to your battery where your fuses should be for the lights and properly crimp your wires
17) HAVE FUN PUTTING EVERYTHING BACK INTO PLACE
I will be updating this in the next few days to add things that I have forgotten. Please feel free to PM if you need any help
Old 05-15-2007, 08:16 AM   #5
97 ZJ Steve
no pictures of the lights?!?!
www.JeepPassion.com
A great jeep blog by a jeeper for jeepers.
97 ZJ Steve is offline   Reply With Quote
Old 05-15-2007, 09:31 AM   #6
th3godf4th3r
and the final pics:
Old 05-15-2007, 03:33 PM   #7
dooboy2112
That's awesome Now how about for a WJ
2000 Grand Cherokee Limited
2000 Wranger Sport SOLD
1979 Wagoneer SOLD
http://www.oclakerfans.com/
dooboy2112 is offline   Reply With Quote
Old 05-15-2007, 03:38 PM   #8
Texas WJ
Texas WJ's Avatar
2005 WK
Excellent write up.
Texas WJ is offline   Reply With Quote
Old 05-15-2007, 03:55 PM   #9
froggo27
looks good, .wish there was a way to get rid of that hudge wire bundle between the rack and tail gate.
Kamil
04 WJ Limited
My Trail Pics!!
froggo27 is offline   Reply With Quote
Old 05-15-2007, 06:20 PM   #10
Ds4x4
drill a hole where it's not noticeable.. anyways. good write up for not drilling the roof.. i drilled a 1/4hole and ran the wires from the roof, down the A-piller and thru the fender .. much much easier..
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline   Reply With Quote
Old 05-15-2007, 06:29 PM   #11
th3godf4th3r
do you have a pic of that?? I dont know how people are doing that with the kind of rails the ZJ has
Old 05-15-2007, 07:47 PM   #12
Ds4x4
sorry i don't have any of the wires run down the a-piller i just took the molding off and ran the wires.. replaced the molding and everything was fine..
Old 05-17-2007, 01:38 AM   #13
scubatch2
I ran mine through the inside channel of the factory roof rack.then I removed 1 screw from the rack and ran the wires through the hole and down. if needed i can take some pic's.
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
jeep pics
scubatch2 is offline   Reply With Quote
Old 05-17-2007, 01:58 AM   #14
CLNinja
thats what i plan on doing...removing a scre from the roof rack...running the wires thru it and applying silicone to hole so water doesnt leak thru
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Old 05-17-2007, 08:46 AM   #15
th3godf4th3r
that would be good!
Glock Forum
