UK NP249 Transfer Case Swap (+ PICS) - JeepForum.com
post #1 of 5 Old 07-11-2009, 11:56 AM Thread Starter
UK Cherry
Bonjour
(pics below)
After running with a failing viscous coupler in a 1997 Grand for over a year and stuggling to park the vehicle without it bunny-hopping into position, I elected to either replace the VC or the case.
Considering the VC was about 200 + 150 shipping from the US and I could source a nice NP231 (command-trac) or NP242 (selec-trac) for considerably less, I chose to source a replacement TC. Sure enough, a 231 off a 1997 Cherokee turned up in London for 50.
The swap took a couple of weekends, as I wasn't rushing. Removing and dropping the old 249 wasn't that bad ......I only weigh 10.5 stone and am not especially strong
The input shafts had a different spline count (21 vs 23) so had to strip the cases down and swap the input shafts. It was useful exercise as I could see the condition of the new case and it looked new inside with minimum deposits on the magnet. I ordered a NP231 seal kit from Ebay US and fitted a new transmission output shaft seal to the back of the transmission and new seals at either end of the transfer case.
After refitting, the shifter mechanism needed no adjustment and driveshafts connected up without issue.
The net result, is the car being driven in rear-wheel drive and moving with much less effort. It also goes around corners and parks with complete ease. I'll try and source a new shifter command-trac surround.
So if anyone's mulling this procedure and has somewhere where they can leave their car with the back of the transmission missing for a while, I would recommend it.
G.
Hmmm...these look a bit large. Anyone know how to change the resolution on this site?
UK Cherry is offline
post #2 of 5 Old 07-11-2009, 12:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
those pictures are way too small, i can't see anything.
might wanna put a "no less than t1 line click here" warning in the title.
ratmonkey is offline
post #3 of 5 Old 07-11-2009, 12:18 PM
blackjack12982
1994 ZJ
Holy s*$t! Those pics are almost big enough for wall posters! But good info for sure, I'm gonna be doing this in the distant future. Thanks!
blackjack12982 is offline
post #4 of 5 Old 07-12-2009, 02:40 AM Thread Starter
UK Cherry
...shrunk 'em.
G.
post #5 of 5 Old 07-12-2009, 07:09 AM
zjBAMF
you know i work in the factory that makes those, but ive never stopped to look how they are fit together , kinda cool seeing all the parts in thier place
Barry Badrinath: It's $10 for a BJ, $12 for an HJ, $15 for a ZJ...
Landfill: [Interrupting] What's a ZJ?
Barry Badrinath: If you have to ask, you can't afford it.
Steve "Fink" Finklestein: [Trying to persuade Landfill] I've got $4.
zjBAMF is offline
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
247 to 242 transfer case swap theviper90210 ZJ Grand Cherokee Forum 25 07-18-2007 10:29 AM
Transfer case help NP249 kinda long, sorry.. airtraffic ZJ Grand Cherokee Forum 4 03-29-2007 06:53 AM
ATF+4 in NP249 Transfer case? ojingalena ZJ Grand Cherokee Forum 6 04-19-2005 06:53 PM
