ujointed front driveshaft for 46rh - Page 2 - JeepForum.com
post #16 of 20 Old 04-10-2013, 11:18 PM Thread Starter
moparlover1992
Well maybe I will car-part.com this.... There are very few jeeps at my u pull it junkyard so that may be the only other option. Thank you all for the tips. And ya so far the lift is going good. Trying to do it right, do it once... We will see how that works out
95 zj 5.2 np242 3.5'' IRO lift, IRO adjustable arms, KOR front trackbar, steering stabilizer and box brace, IRO rear adjustable trackbar, bilsteins, Hughes plenum plate, flow master 40, 31x10.5s on 15'' dc-2 rims
Mopar or no car!
moparlover1992 is offline
post #17 of 20 Old 04-12-2013, 07:30 AM Thread Starter
moparlover1992
Originally Posted by dnuccio View Post
Find a u joint driveshaft out of a 93-95 ZJ with the v8
I want to thank you for this suggestion. Looking on car-part.com under 93 grand Cherokee there is both a cv boot shaft and a u joint shaft option. Around $80 average at yards about an hour away. I'll have to take my cv shaft with me when I go to confirm the length is good, but this is an exciting find as it should be the exact length I need. I will not be to this point for a few months yet, but I'll update when I find out
Mopar or no car!
post #18 of 20 Old 04-12-2013, 02:14 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the lengths will be different between cv and u-joint shafts. the cv yoke is longer than the u-joint pinion yoke.
ratmonkey is offline
post #19 of 20 Old 04-12-2013, 11:59 PM Thread Starter
moparlover1992
yes but i already swapped the yoke. wont the shaft in the 93 be longer than my cv shaft since it has a 46rh just like mine but the u joint yoke at the differential(since the difference in yokes is an inch)?
Mopar or no car!
post #20 of 20 Old 04-13-2013, 12:01 AM Thread Starter
moparlover1992
and ratmonkey thanks a lot for your replies. nice to get info from someone with a great reputation and an amazing build thread
Mopar or no car!
