Uh OH! - JeepForum.com
post #1 of 5 Old 08-25-2012, 07:45 PM Thread Starter
JohnHancock
Uh OH!
So I am afraid that I believe my VC is going bad:/. I found this 242 transfer case on eBay will it swap into my jeep? I have a 97 5.2l v8
http://item.mobileweb.ebay.com/viewi...285&cmd=VIDESC
Also how hard is it to take out the front drive shaft for a temp fix?
JohnHancock is offline
post #2 of 5 Old 08-25-2012, 07:52 PM
sskilla
you may have to swap the input shaft with the one in your 249, but it should work.
removing the front DS is easy, just a few little bolts.
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #3 of 5 Old 08-25-2012, 07:53 PM
WhiteOut
WhiteOut's Avatar
4 bolts at the transfer case and 6 at the diff. Should be an 8mm wrench for all. Before you do, get the jeep up to operating temp and go do some figure 8s in a parking lot. If it sounds like it is scrubbing the tires and hopping, the VC is going bad.
Removing the front driveshaft will not have any negative effects on the jeep.
WhiteOut is offline
post #4 of 5 Old 08-25-2012, 08:00 PM Thread Starter
JohnHancock
So I did some figure 8s but it doesnt hop it almost sounds like the front end has like metal stretching. It's very odd hard to explain
post #5 of 5 Old 08-25-2012, 08:12 PM
WhiteOut
WhiteOut's Avatar
Try removing the front driveshaft then. If it still does it, you have another issue.
WhiteOut is offline
