UC suspension on a stock ZJ... - JeepForum.com
post #1 of 34 Old 02-06-2012, 07:35 PM Thread Starter
JeepinJordan
I have a ZJ with stock suspension but what do I need for it to have the Upcountry package(Suspension components and tire size) and where can I score these. I dont want a puck lift or anything, but more of just a bigger, beefier stock suspension(I read the UC gave about a 1inch lift?). I want to keep this my daily driver and tow rig.
Also I am thinking about using newer shocks, what do you guys prefer for stock on a UC package without sacrificing the ride height and apperiance.
Let me know!
-Bone stock 1996 Jeep Grand Cherokee Laredo 4.0L
JeepinJordan is offline
post #2 of 34 Old 02-06-2012, 07:46 PM
nicklopic
the upcountry suspension included stiffer coils and Sachs-Boge shocks. the ride height was 1" over stock
i believe you might be able to get the components from the dealer stiff... i doubt it though
as for the springs, i got a set off of a guy on craigslist but it took a long time to finally find them and they have high miles on them. (sad thing is I don't even want to use them anymore and they've just been sitting in my garage)
you could check junkyards too. if you found the shocks that came with the package they'd probably be shot at this point.
if you want new components, you could get old man emu coils and bilstein shocks
heres some info on it all http://www.kevinsoffroad.com/techart...coupgrade.html
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #3 of 34 Old 02-06-2012, 08:04 PM
squazz
I just did this to my 94 and even without shocks it rides so much better. Any orvis you find in a JY will have the Upcountry 1" springs and Kolak has a good deal on Blistens i just recieved mine today. i have 4 orvis' in a local yard i might go back and get a few more sets of springs. A v8 tierod would also be a upgrade for your 4.0
squazz is offline
post #4 of 34 Old 02-06-2012, 08:13 PM Thread Starter
JeepinJordan
Thanks, yeah I was just reading that, I just want a better ride and a slight ride height adjustment for when I haul. I would think that most of the old UC suspension, if i were to find any, would be worn, and I dont want that. I will check out the emu coils though.
What about tires? Did the UC come with larger?
post #5 of 34 Old 02-06-2012, 08:19 PM Thread Starter
JeepinJordan
Would I need longer shocks for the OME springs?
post #6 of 34 Old 02-06-2012, 08:24 PM
nicklopic
Depends on the springs you get, I think they sell them 1-3" longer
I know they have different spring rates based on the kind you buy, ie. Heavy duty and such
The package I don't believe came with bigger tires, but im not sure. The manual does list 2 different size tires in mine
you'd probably be able to fit 30s but I'm really not sure on that. There's something in the faqs that might help so ill look at that real quick
98' ZJ 4.0
post #7 of 34 Old 02-06-2012, 08:28 PM
nicklopic
98' ZJ 4.0
post #8 of 34 Old 02-06-2012, 08:45 PM Thread Starter
JeepinJordan
Thanks! I found this if anyone else is looking on doing the same thing:
http://www.jpmagazine.com/featuredve..._zj/index.html
post #9 of 34 Old 02-06-2012, 09:06 PM
nicklopic
not a problem, glad i could help
98' ZJ 4.0
post #10 of 34 Old 02-06-2012, 09:38 PM Thread Starter
JeepinJordan
yep, as with the tires, I dont think my 225/75s would look silly on a 1-1 1/2 " spring lift right?
post #11 of 34 Old 02-06-2012, 09:46 PM
Oldfrog
2007 WK
My 97 ZJ with U/C came with 245/70 R15's on it, new. I still have the original spare too...lol ! I think the original front shocks were mounted upside down too, as I recall.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #12 of 34 Old 02-06-2012, 10:16 PM Thread Starter
JeepinJordan
Could you show your 245/70 set up?
post #13 of 34 Old 02-06-2012, 10:33 PM
BlackDaddyZJ
1994 ZJ
if your hauling stuff a lot it might be good for you to get air bags for the rear springs. i have them in my zj from when my dad used to tow with it and they help it to not squat dwn so far when loaded
Bob
'94 ZJ
5.2L
IRO 4.5" Lift
35x12.5 Mickey Thompson Baja MTZ's
98 5.9
Restored and daily driven
BlackDaddyZJ is offline
post #14 of 34 Old 02-06-2012, 10:36 PM
Oldfrog
2007 WK
Not now, because I no longer run those tires....but if it's something you doubt, they are probably listed on the original window sticker, which I still have. ( I ordered it new)
Oldfrog is offline
post #15 of 34 Old 02-07-2012, 10:10 AM Thread Starter
JeepinJordan
Like the Firestone Coil-rite kit?
Pretty cheap I like it. Mine does squat too.
zj
98 ZJ Stock Suspension Rebuild smuengr08 ZJ Grand Cherokee Forum 2 01-05-2011 12:43 PM
Stock suspension parts 93' amp0804 ZJ Grand Cherokee Forum 0 07-28-2010 09:25 PM
Max Hieght With Stock Suspension Is... HAMM ZJ Grand Cherokee Forum 5 07-11-2008 06:00 PM
Stock suspension measurements. _Kyle_ ZJ Grand Cherokee Forum 4 03-21-2008 06:34 PM
New 245/75/16 on stock suspension 3fifty ZJ Grand Cherokee Forum 6 08-12-2007 09:29 AM
