Quantcast Two questions within... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Two questions within...
Old 02-26-2007, 02:53 PM   #1
turk
Exhaust
First, these may be related,
Anyone out there know the temp of there muffler and or tailpipe (I am running a flowmaster 50 series) I took a temp about a month ago and it was running 497 degrees. Aside from the flowmaster, I also have a high flow cat, k&n intake and a jet chip stage II. Is there a chance that the air to fuel mix is off causing a higher temp?
The other issue is... while coming to a semi-abrupt stop, the Jeep drops in RPM and almost stalls (Has not yet, but still may). A previous post I left got a response that it may be the fuel pump (the drop in RPM and it was also choking around corners when on 1/4 tank of gas. So do these two problems sound like a fuel pump issue?
Any Help appreciated,
Turk
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline   Reply With Quote
Old 02-26-2007, 04:54 PM   #2
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Have you taken the chip off and taken the temp?
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 02-26-2007, 06:00 PM   #3
turk
Not yet. I have only recently notice any probs with the bogging. The temp I never check the temp difference from stock to mod. Though I have been running with the same set up for 4 years and never bothered to check temp. I would guess that with the mods there is a possibility of a uneven fuel/air ratio. One other thing, also recently I have notice a lower fuel economy. Maybe I am not getting good spark and therefore, have some fuel burning in the exhaust???? Finally, I have never changed the fuel filter or the fuel pump since I have owned the vehicle (6 years)
turk
Glock Forum
