Two problems that may or may not be related - JeepForum.com
post #1 of 3 Old 08-14-2013, 06:29 PM Thread Starter
Styxun
1998 Jeep Grand Cherokee Limited 5.2L V8 with Quadra-Trac I 4WD.
First off, excuse me if I sound like a noob, as this is my first Jeep. I've done a bit of work on it myself, so I've gotten a generic understanding of some of the parts, but some of it is still giving me problems. When I bought the thing, there were a few problems: an ABS sensor light, the passenger side floorboard flooding, the coolant sensor fault light on the VIC, and loud clicking when I turn too sharply.
I used the guide for the coolant sensor fix, re-soldered the cracked pin and that was golden. I did the traditional fix for the passenger side A/C flooding and got a wet-dry vac in there and sucked up all the water, but a few days later, it was standing water again. I took it to the dealership and they said they could do a thorough cleaning of the A/C drain for $200, and they did. However, days later it was standing water once more. It's not flooding the rear passenger side floorboard anymore, so that may be relevant.
I'm getting the brakes taken care of soon here so hopefully they'll take care of the ABS sensor as well. However, it's the clicking and the flooding that's giving me the most problems. I read the guide where you cut open the wheel-well and put a length of tube in there to help with water draining, but I don't really want to cut into the frame just yet before all other avenues are looked into.
The clicking usually happens when I turn too sharply, and it makes the whole car shake and can be heard from quite some distance away. It clicks faster when I accelerate and sometimes even after I straighten out from a turn. However, sometimes after I come to a complete stop, I have to rev it up to about 1k-1.5k RPM before it will jerk forward and start moving. I recently had the B-02 recall fix for the floor shifter not being in park, but that wasn't really a problem, however now when I shift to reverse, it has to be rev'd to 1k to 1.5k before it will move backwards as well.
I'm pretty sure the vehicle is mostly stock, so it may rule out a lift problem, but since the clicking speeds up when I accelerate, could it be a problem with gears? The guy I bought it from had a lot of work done on it before he sold it to me like the axles and joints, so I doubt it'd be a bad CV joint.
As for the water problem, we originally thought it could be the sunroof, but the headliner isn't wet, and the sunroof appears to have already been resealed with a form of clear-vinyl.
I know I've been rambling, but any help would be great.
Styxun is offline
post #2 of 3 Old 08-14-2013, 06:47 PM
dnuccio
viscous coupler is likely the cause of your "clicking". do a search on here, you'll find tons of info on it
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 3 Old 08-14-2013, 08:04 PM
JasonStebbins
Sounds like a bad CV axle or bad U-joints to me. Bad CV joints click when you turn to sharp when they are bad. Either of those could cause binding. A bad VC inside the transfer case will cause binding as well.
The water sounds like a clogged A/C drain, very common.
Check the transmission dipstick while running warm in neutral for the shift lag.
The ABS light is usually a broken wire or bad sensor at the axle, next to the tone rings.
Poop
JasonStebbins is offline
