TV cable Issues?? - JeepForum.com
post #1 of 3 Old 06-17-2013, 08:03 PM Thread Starter
SGSZJ
TV cable Issues??
I have a 96 Zj 4wd 4.0 and I am having issues with the tv cable sticking I have tried just about everything I can think of replaced the spring lubed it with wd-40. Im not sure where the problem is, as in if its the cable itself or the bracket. I have not been able to find someone else who has had the same problem so im at a loss any Ideas????
SGSZJ is offline
post #2 of 3 Old 06-18-2013, 12:04 AM
96zedjay
Does the bellcrank (lever) on the x-mission move freely with the cable disconnected?
If so, good possibility the inner wire on the cable is starting to fray and the cable needs replacement.
96zedjay is offline
post #3 of 3 Old 06-18-2013, 09:22 AM Thread Starter
SGSZJ
I will check that and let you know.
SGSZJ is offline
