TV cable - JeepForum.com
post #1 of 17 Old 04-21-2013, 09:27 AM Thread Starter
dylantheheeler
TV cable
Alright, so I've got this shifting problem from 1-2 gears. It's feels like it shifts to second and then back to first and then back to second. The weird thing about it is when I adjust my kick down cable, it almost eliminates the problem for a day or so, and then it comes back. I put a junkyard cable on it and it does the same thing. What does this sound like?
Thank you
Sent from AutoGuide.com Free App
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline
post #2 of 17 Old 04-21-2013, 11:20 AM Thread Starter
dylantheheeler
Anyone?
post #3 of 17 Old 04-21-2013, 02:51 PM
KoreaZJ
1994 ZJ
Make sure the return spring is installed properly on the tranny end of the TV cable. Sometimes one end pops off.
Mine usually shifts differently each time the battery has been unhooked. Most consistent if I unhook battery (NEG cable), let it sit for a few minutes with key ON to drain circuits, key OFF, rehook cable, start, idle a few minutes, then do several normal constant accelerations between 0 and 60mph on a straight level road.
KoreaZJ is offline
post #4 of 17 Old 04-21-2013, 02:57 PM
StrateLOSS
where is that and how can I adjust.
I searched for a how-to in the FAQ and can't find it
StrateLOSS is offline
post #5 of 17 Old 04-21-2013, 03:07 PM Thread Starter
dylantheheeler
I'm starting to think its time for a new governor solenoid and sensor. It's been this way for a few months. My cable return spring is attached fine. When applying only a little throttle it bucks from 1st to 2nd and it does that until I give it more gas.
post #6 of 17 Old 04-21-2013, 03:09 PM Thread Starter
dylantheheeler
The adjustment for the kickdown cable is just left of the throttle body (assuming you have the 4.0). It's a white clip. Pull up on it and there are little teeth on the cable. Move the cable in and out to adjust. Adjust it very little at a time.
post #7 of 17 Old 04-21-2013, 03:14 PM
adhdlacrosse16
2014 JK Wrangler
i just posted earlier this week about this problem. tv cable adjustment seems to fix it for aqhile but it alwyas come back. I had it in the shop and they said trans sensors were in the normal range. i have not looked into the spring yet but i will later tonight and let you know
99' WJ... tank raise mesh grill homebrew cai
magnaflow 11226, banks header, bb sittin on 31s
adhdlacrosse16 is offline
post #8 of 17 Old 04-21-2013, 03:34 PM Thread Starter
dylantheheeler
That's very strange. Does yours do the same thing as mine?
post #9 of 17 Old 04-21-2013, 03:44 PM
adhdlacrosse16
2014 JK Wrangler
seems like it to me here is the thread http://www.jeepforum.com/forum/f310/...ubles-1511197/
post #10 of 17 Old 04-21-2013, 03:47 PM Thread Starter
dylantheheeler
That sounds like mine. I think I might order a new governor solenoid and sensor and see if that cures it.
post #11 of 17 Old 04-21-2013, 03:54 PM
adhdlacrosse16
2014 JK Wrangler
keep me updated on it please
post #12 of 17 Old 04-21-2013, 05:19 PM
StrateLOSS
thank you, just picked up my ZJ and know very little about Jeeps in general at the moment.
post #13 of 17 Old 04-21-2013, 05:21 PM Thread Starter
dylantheheeler
I'll send you a pm to let you know if it fixes it bud.
post #14 of 17 Old 04-22-2013, 10:04 AM
zjosh93
Mine did that same thing 1-2-1 a awhile back. I already changed the sensor and solenoid. Adjusting the cable helped but did not eliminate the issue. Turned out I was leaking fluid slowly and was just a half quart low. The 42RE is sensitive. Added fluid and no more problems.
zjosh93 is offline
post #15 of 17 Old 04-22-2013, 03:09 PM Thread Starter
dylantheheeler
I've had a leak from the pan for a while and couldn't get it to seal with just the rubber gasket. Today I took the pan off and changed the gasket out with a new one. Used rtv on both sides of the gasket and refilled the fluid. Problem is gone. Thank you very much, I've been chasing this problem for a while now.
