turns but wont start - JeepForum.com
post #1 of 9 Old 01-31-2013, 01:12 PM Thread Starter
justinspotanske
I have posted this a few times and nothing yet has worked so I thought I would give it another try . Once in a while when I go to start my 93 grand cherokee whith a 4.0 it turns over fine but will not start . I have to try several times just to get a sputter . When it decides to sputter on the next crank I will floor it and it will usually start . Will run like crap for a few seconds but everything evens out . I have in the past year replaced the fuel filter , plugs , wires , cap , rotor , iac , and air filter . I am out of ideas of this issue since after awhile it will start . Any ideas to concider or check ?
justinspotanske is offline
post #2 of 9 Old 01-31-2013, 01:39 PM
melk
Crank sensor, TPS
melk is offline
post #3 of 9 Old 01-31-2013, 02:24 PM
DirtDodd
Could it be the O2 sensor?
And is the check engine light on? Have you cycled the key on and off three times to check for codes?
And there is a great resource on here that has helped me checking my 93 out called "12 things to check" or something like that if you haven't found that already. Very helpful write-up!
DirtDodd is offline
post #4 of 9 Old 01-31-2013, 04:04 PM Thread Starter
justinspotanske
I have a new o2 sensor and no lights are on or have been recorded by cycling the key
post #5 of 9 Old 01-31-2013, 04:37 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
classic symptoms of blown caps in the PCM.
ratmonkey is offline
post #6 of 9 Old 01-31-2013, 05:11 PM
nckmbl
Check the automatic engine shutoff fuse under the hood.
nckmbl is offline
post #7 of 9 Old 02-19-2013, 10:28 AM
wolfjeep73
i am having the same issue i found it wont start untill the check engine lite comes on then it will start no problem is there a way to fix this issue
wolfjeep73 is offline
post #8 of 9 Old 02-19-2013, 06:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's blown capacitors in the pcm. long history of those problems in 93-95 jeeps. a google or jeepforum search will give you the info you need.
post #9 of 9 Old 02-19-2013, 08:58 PM
wolfjeep73
ty ratmonkey this is my second 93 and it has the i6 my first had the v8 and all wheel drive i like my new one better but i am seeing the same issues in this one as i had in my last one like leaking fuel when i fill the tank and not shifting properly i need to get this one on the path to a good life so i can make her into a real trail rig for me and my kids to have fun in
