Turning judder - JeepForum.com
post #1 of 17 Old 12-19-2007, 12:14 PM Thread Starter
james157
Turning judder
When i use alot of steering left or right when pulling off i get a judder until i straighten the steering a bit.
Is this low oil in the front diff or am i looking at a bigger bill?
james157 is offline
post #2 of 17 Old 12-19-2007, 12:20 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
how fast are you going when it happens? how tight of turns? pulling into a parking spot kind of turns, or turning onto a street kind of turns? what kind of transfer care do you have? have you checked the fluid level yet, that takes all but 5 mintes?
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #3 of 17 Old 12-19-2007, 02:19 PM
Pretty C
The quadra trac ZJ can bind when turning at lock. Do a figure 8 and see if it happens consistently. At that point it could be a few things
Pretty C is offline
post #4 of 17 Old 12-19-2007, 02:26 PM
Adriansaxton
I had the same problem, get your tracking checked. My tracking was out, now allinged, no judders on tight lock, cheap fix. Good luck. Ade.
Adriansaxton is offline
post #5 of 17 Old 12-19-2007, 03:44 PM Thread Starter
james157
Pulling out of a junction or going round a mini roundabaut and it will do it.
Dont know what transfer case i have,sorry.
Havent checked the fluid yet but i will asap.
james157 is offline
post #6 of 17 Old 12-19-2007, 07:29 PM
om4eccv
I didn't want to start a new thread.
I've got a Selectrac (that's a 242, right), and have the same sort of issues when pulling into parking spaces and making tight, slow corners.
I've searched, and the Viscous Coupler doesn't seem to apply to the 242.
What's the next thing to check?
97 ZJ, I6 4.0, Stock. 170K+
om4eccv is offline
post #7 of 17 Old 12-19-2007, 08:24 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
what options does your t-case shifter bezel say? ie: 4LO - N - 4 ALL TIME
im pretty sure the VC is shot in your transfer case is shot, but do a bunch of tight figure 8s in a parking lot to be sure. search for "viscous coupler".
your cheapest option would be to swap in a junkyard t-case. if you swap in a 242 its much less likely to go out again.
post #8 of 17 Old 12-20-2007, 02:46 AM Thread Starter
james157
That is what it has 4LO - N - 4 ALL TIME
What is a 242 and how can i tell the difference?
Can you tell im a noob to my jeep.
james157 is offline
post #9 of 17 Old 12-20-2007, 03:43 AM Thread Starter
james157
Done a search and it looks like it is the viscous coupler,i will be searching for a 242 for mine.
Thanks.
james157 is offline
post #10 of 17 Old 12-20-2007, 04:41 AM
sandman
yea you have the 249 and its probably a bad VC
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 17 Old 12-20-2007, 11:57 AM Thread Starter
james157
Did the WJ come with a 242?
Newer so hopefully lower miles.
Not sure which models i need to be looking for in the ads to find one.
james157 is offline
post #12 of 17 Old 12-20-2007, 12:05 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You can't use a WJ's 242. The WJ 242 doesn't have an output shaft speed sensor which is what the ZJ uses for the speedometer.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #13 of 17 Old 12-20-2007, 12:13 PM
Pretty C
This gent is going to have a hard time finding any parts in a junkyard in the UK.
I saw one WJ in two weeks in scotland last year.
Pretty C is offline
post #14 of 17 Old 12-20-2007, 02:34 PM Thread Starter
james157
I think your right,but i will keep looking.
Just need to know which models and years i can use?
james157 is offline
post #15 of 17 Old 12-20-2007, 02:58 PM
Pretty C
There are few write-ups i've seen recently on switching t-cases in a ZJ. Search this forum or get one of the vets to recomend years or a place to find the swap write up.
Pretty C is offline
Grinding while turning aeggerth ZJ Grand Cherokee Forum 20 02-25-2015 07:20 PM
94 zj turning problem 96fleXJ ZJ Grand Cherokee Forum 1 08-09-2009 10:52 PM
02 WJ - Key not turning fin88 ZJ Grand Cherokee Forum 9 11-30-2008 11:57 PM
Judder when coming off gas pedal naiku ZJ Grand Cherokee Forum 25 11-04-2007 12:03 PM
HELP!!! I'm turning into Phil! ZgreatJ ZJ Grand Cherokee Forum 15 03-03-2006 03:12 PM
