turn signal relay fell out.... - JeepForum.com
post #1 of 4 Old 07-27-2009, 05:26 PM Thread Starter
wickerham
....again!!!
I asked questions about my signals not working, solved the problem (relay fell out) and posted it. But now, it fell out again. Any reason it would keep falling out? This makes twice and I've owed my ZJ less than a month. Think if I bend the metal prongs out a bit (like you would with a house wall outlet type plug) it would stay in better? Would this harm the relay?
wickerham is offline
post #2 of 4 Old 07-27-2009, 05:46 PM
ZeeJay1997
Originally Posted by wickerham View Post
....again!!!
Try disconnecting the battery and using an awl or similar tool to GENTLY pry the socket contacts together. Use a good light to see how the contacts are assembled before you start.
ZeeJay1997 is offline
post #3 of 4 Old 07-28-2009, 06:59 PM Thread Starter
wickerham
"crawled" up in there yesterday, flashlight in mouth! Found the previous owners duct tape still there (I see how they kept 'em in) I re-taped them. Works for now.
post #4 of 4 Old 07-28-2009, 07:52 PM
ZeJokee
I think this might be a common problem. My previous owner had tape around the flasher also.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
A/C, Turn signal 2001Limited ZJ Grand Cherokee Forum 3 10-23-2015 07:34 PM
I need help! Turn signal/ Turn signal switch problem orangepower1987 ZJ Grand Cherokee Forum 8 09-15-2009 11:19 PM
Need help with turn signal/flasher relay location 94 zj darren2569 ZJ Grand Cherokee Forum 3 08-03-2009 05:32 PM
02 Wj Bizarre turn signal wont turn off mountcharles ZJ Grand Cherokee Forum 0 05-05-2009 02:51 PM
turn light flash relay cojimero ZJ Grand Cherokee Forum 2 09-09-2008 06:00 PM
