turn signal lens broken, what's the easiest fix? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > turn signal lens broken, what's the easiest fix?
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 04-02-2004, 04:28 PM   #1
Camster
Well got in an accident a while back (backed into someone) didn't do any damage besides busting my turn signal, drivers side rear. The light itself is fine it's just the orange plastic covering that's broken. It caused me to fail inspection. I was wondering what the easiest fix for this problem would be. Will it require replacing the whole break light unit or can i get by doing something else. cost is defnitely a consideration. thanks.
96 ZJ
Cameron
[url=http://www.angelfire.com/nc2/davidpage/Camsjeep.html]My Jeep[/url]
Camster is offline   Reply With Quote Quick reply to this message
Unread 04-02-2004, 05:21 PM   #2
greasefingers
1994 ZJ
If you do not replace the whole unit, then it could leak. Search ebay to save $$
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote Quick reply to this message
Unread 04-02-2004, 09:34 PM   #3
Meerkat
96 ZJ
A couple things come to mind. First, the law says you can't have any white lights (other than back up) on the rear of your vehicle. When the orange lens breaks, you suddenly have white light from the bulb shining forth. Nothing says you have to have a colored lens, just that your turn signal has to be amber, and visible for a certain distance. Technically, you could replace your white bulb with an amber bulb and pass inspection. Of course, the inspector may or may not see it your way. Alternatively, they used to sell, and probably still do sell, turn signal lens repair kits at the auto parts stores, such as Auto Zone.
Hey, I just did a quick check, and guess what? Ace Hardware sells just what you need, I think.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote Quick reply to this message
Unread 04-02-2004, 09:56 PM   #4
10achik
I ate what?
10achik's Avatar
Had the same thing happen to me but it was the rear brake light, I went to the junkyard and pulled the whole assembly in about 2 minutes, it's just a couple of screws and unplug the lights. Cost me about $50...Good luck finding one.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote Quick reply to this message
Unread 04-03-2004, 08:53 AM   #5
Camster
Ok guys, thanks. I'm going to go check out AutoZone first, see if i can find a solution. If that doesn't work i'll head to the junkyard.
Cameron
Unread 04-03-2004, 03:26 PM   #6
DrumBoy
I say just bite the bullet and replace it. I just looks better and you will be sure to pass inspection. Like "Greasefingers" said, Ebay is a great place for finding an used OEM lens since there are some people buying those Altezza lenses they are turning around and selling their perfectly good OEM's and that's where you might save a few $$$.
Or try http://www.quadratec.com/cgi-bin/sgd...04040316210288 they have an OEM section as well.
Good Luck Hunting,
DrumBoy.
1998 Grand Cherokee Laredo I-6
K&N FIPK
Gibson GP400S Header
Kolak 2.5" exhaust system
Flowmaster 50
Bored TB w/Poweraid TBS
Optima Yellow Top Battery
Mean Green Alternator/Starter
DrumBoy is offline   Reply With Quote Quick reply to this message
