Turn Signal Flasher - Where is it located?????? - JeepForum.com
post #1 of 12 Old 03-16-2004, 06:26 PM Thread Starter
Esox23
Recently my turn signals started to slow down, and today they just stopped working all together. I don't have any bulbs burnt out, my turn signals stay light and don't flash when I turn on my blinker. I picked up a new flasher but I have NO IDEA where it is. I have a 1993 Jeep Grand Cherokee 4.0L.
Can someone please help??? I don't have a Hayes Manual or anything like that which is why I'm having a hell of a time locating it.
Esox23
Esox23 is offline
post #2 of 12 Old 03-16-2004, 07:12 PM Thread Starter
Esox23
Esox23
Yeah i found it what a joke, they couldn't have put it in a more jacked location, anyway it has been found and replaced and did cure the problem. Oh by the way it was under the steering column hidden behind the ding ding indicating you left your keys in the ignition.
Esox23
Esox23 is offline
post #3 of 12 Old 03-16-2004, 07:26 PM
Jillie
Jillie's Avatar
I have my Haynes manual in front of me and this is what it says...i typed it quickly so ignore the spelling mistakes : (i have the illustration infront of me)
The illustration says: The turn signal and hazard flashers are mounted on the back of the convenience center on the 1993 models- in the interior fuse/relay panel on later models.
Turn Signal/hazard flasher-check and replacement:
Warning: These models are equipped with airbags. The air bab is armed and can deploy anytime the battery is connected. To d\isconnect the negative battery cable whenever working near the airbag components.After the battery is disconnected, wait at least 2 minutes before begining work (the system has a back up capacitor that must fully discharge)
The turn signal/hazard flasher is a small canister shaped relay that flashes the turn signals and hazard warning lights when either switch is activated. On 93 models, two separate units are mounted on the back of the convenience center located under the dash on the drivers side.
When the flasher unit is functioning properly, an audible click can be heard during its operation. if the turn signals fail onj one side or the other and the flasher unit doesnt make its characteristic clicking sound, a faulty turn signal bulb is indicated.
If both turnj signals fail to blink the problem may be due to a blown fuse, a faulty flasher unit, a broken switch or a loose or open connection. If a quick check of the fuse box indicates the turn signal fuse has blown, check the wiring for a short before installing a new fuse.
To replace the flasher simply detach it from its electrical connector and plug in the new one.
Make sure the replacementis identical to the original. compare the old one to the new one before installing it.
97 I6 ZJ
K&N FIPK
Flowmaster muffler
Jillie is offline
post #4 of 12 Old 03-16-2004, 07:44 PM
Jillie
Jillie's Avatar
Well i am glad you found it.......
i was typing it while getting my boyfriends son cheezits and juice and answering all of his questions about Shreck while we watched it.....otherwise i would have replied sooner
97 I6 ZJ
K&N FIPK
Flowmaster muffler
Jillie is offline
post #5 of 12 Old 03-17-2004, 07:03 AM Thread Starter
Esox23
Jillie thank you very much for taking the time to type all that out, i appreciate it.
Esox23
Esox23 is offline
post #6 of 12 Old 03-17-2004, 07:11 AM
Jillie
Jillie's Avatar
You're welcome.
97 I6 ZJ
K&N FIPK
Flowmaster muffler
Jillie is offline
post #7 of 12 Old 03-18-2004, 05:08 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
"convenience center" - NOW THERE IS THE JOKE....
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #8 of 12 Old 11-22-2005, 08:49 PM
schwa
1994 ZJ
for the 1994 Grand Cherokee Limited model
this is what I found in the glove box (convience center?!?)
I turned ont he hazard lights to locate the origins of the clicking noise, and with the turn signals. As for whats under the steering column on the right side, must be for a different model.
When my flashers / hazard lights stopped then came back on I wiggled this fuse/relay/whatever and seems this is the culprit. Now I'm wondering if its this or the relay or controller that it sits in that might be the problem as well.
Maybe someone can shed some light.
As the guys at the dealership have said, this is the "flasher"
and this is where it's located in the glovebox.
schwa is offline
post #9 of 12 Old 11-22-2005, 10:39 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
That's it, but you realize this thread is more than a year old? Do you have any other questions?
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #10 of 12 Old 11-23-2005, 04:46 AM
schwa
1994 ZJ
no, i just wanted some closure on what the cause was
schwa is offline
post #11 of 12 Old 02-27-2011, 03:13 PM
eliX0r
1994 ZJ
I just bought a 1994 Jeep Grand Cherokee Limited and the turn signal and hazards don't work. I did a search and it brought me here but the diagram or pictures he had are gone and i have no manual. So i have no idea which fuse is the turn signal hazard flasher.
eliX0r is offline
post #12 of 12 Old 05-18-2012, 04:07 PM
rfd578
I have the flasher issue, found the flasher, but it will not budge, even with pliers. Of course now nothing flashes. Any ideas?
Can I spray wd-40 or something up in there to get it loose?
rfd578 is offline
I need help! Turn signal/ Turn signal switch problem orangepower1987 ZJ Grand Cherokee Forum 8 09-15-2009 11:19 PM
Turn signal flasher duanewhatley ZJ Grand Cherokee Forum 2 08-11-2009 08:10 AM
Need help with turn signal/flasher relay location 94 zj darren2569 ZJ Grand Cherokee Forum 3 08-03-2009 05:32 PM
Turn Signal Flasher newnorth ZJ Grand Cherokee Forum 2 02-20-2006 05:19 PM
Where is the turn signal flasher and switch in a WJ? jet190rs ZJ Grand Cherokee Forum 1 05-20-2005 07:41 AM
