Turn key and I got NOTHING... - JeepForum.com
post #1 of 2 Old 08-13-2011, 08:16 PM Thread Starter
98GCLim40
I purchased my most recent Jeep about 6 months ago and I don't think I have gone a week without something going bad.
My new problem has me confused and frustrated more then anything...
Today I got in it at the grocery store and turned the key and got nothing. No lights on the dash, no start. Flustered and back end full of groceries I popped the hood to make sure the connections on the battery were good. CHECK... Got back in and it started right up...
Got home, unloaded groceries and realized I forgot beer (no beer runs on Sunday so this was very important). Got into the Jeep and NOTHING...
Since I was home, I decided to check things over more closely, kept the key turned to on and started pulling fuses in the passenger compartment to see if anything happened - got to fuse #7 (BCM/amp/instru panel) after pulling it the fuel pump kicked on. plugged it back in and dash comes alive. started right up...
Got to liquor store. Same thing. Same fix. Some solution...
I know this isn't a real solution...
I'm thinking BCM but if I got a "new" one from the junk yard will I need to have it flashed at the dealership or anything?
Could it be anything else?
98GCLim40 is offline
post #2 of 2 Old 08-13-2011, 09:55 PM
JeepFreak1982
I have had some funny issues with my 98 5.9 also. I never had one like that but every long once in a whole the gauges dont work, radio turns on but no sound, ac blower blows but not cold, no power windows, and the red LED on the dash for the OEM alarm would stay lit the while time i was drifing. This all leads back to that same fuse. I pull it and all is back to normal. I finally pulled it, cleaned up the terminals real well, put a new fuse in and so far so good.
JeepFreak1982 is offline
1998 jeep grand Cherokee limited will turn over but it will not turn on when it rains 1998jeep727 ZJ Grand Cherokee Forum 31 06-23-2011 07:42 AM
best way to turn ABS off? Travis873o ZJ Grand Cherokee Forum 3 08-11-2010 11:31 AM
Left Turn signal will not turn off BigSensFan WK Grand Cherokee & XK Commander Forum 25 06-29-2010 10:15 AM
I need help! Turn signal/ Turn signal switch problem orangepower1987 ZJ Grand Cherokee Forum 8 09-15-2009 11:19 PM
02 Wj Bizarre turn signal wont turn off mountcharles ZJ Grand Cherokee Forum 0 05-05-2009 02:51 PM
