Turbo help!!! - JeepForum.com
post #1 of 12 Old 09-26-2012, 07:02 PM Thread Starter
kheale1
1994 ZJ
Turbo help!!!
I'm hooking up a turbo on my 94 ZJ 318. Was just wondering, where is the best place to hook up the oil lines? Thanks.
kheale1 is offline
post #2 of 12 Old 09-26-2012, 07:14 PM
DNTTRY
Oil psi sender for supply. Are you using a turbowerx oil pump or going gravity drain? If the latter then you want nothing less than 10an and you need to dump below the turbo and above the oil level in the pan.
DNTTRY is offline
post #3 of 12 Old 09-26-2012, 07:30 PM Thread Starter
kheale1
1994 ZJ
Well I'll be hooking the turbo up where the cat currently is. Might Go with the pump and router it to the oil pan?
kheale1 is offline
post #4 of 12 Old 09-26-2012, 09:06 PM
nicklopic
...you're doing a 5.2 turbo set up???
(I hope you make a build tread)
Pictures please and thank you
98' ZJ 4.0
4.5" short arm, 33" Courser MXTs, custom stubby bumper, skids, someother stuff
nicklopic is offline
post #5 of 12 Old 09-26-2012, 09:18 PM
stormer1092
1994 ZJ
I want to see videos in the future!!!
stormer1092 is offline
post #6 of 12 Old 09-26-2012, 10:47 PM
Mosher
if its an auto tranny you might have problems with it shifting when its in boost
Mosher is offline
post #7 of 12 Old 09-27-2012, 10:45 AM
DNTTRY
How do you plan on tuning it? What fuel and spark mapping tables are you going to use? Are you going to run sd 1,2 , or 3 bar? What iat are you expecting and what counter measures are putting in place to avoid detonation?
DNTTRY is offline
post #8 of 12 Old 09-27-2012, 01:22 PM
JColee
I can't answer a question, but I'd recommend messaging TurboTPI on the forum, he currently has a turbo set up on his I6 and seems to be quite knowledgeable. I'm not saying everyone here isn't knowledgeable, just saying he'd be a great resource.
Good luck, I'd love to see it implemented, step by step so all of us can start picking up parts and bug you for help! Haha.
JColee is offline
post #9 of 12 Old 09-27-2012, 03:28 PM Thread Starter
kheale1
1994 ZJ
I'm not quite the best when it comes to turbos. I'm just going to kinda play it by ear. + I have no clue on how to tune the dam obd 1 in my 94 haha. I know how to hook everything up, but i'm just stuck on the oil feed. I do have every bolt on item possible + upgraded comp cam, but I just figured 15 - 20 LBs of boost will add an extra ooph lol.
kheale1 is offline
post #10 of 12 Old 09-27-2012, 03:42 PM
DNTTRY
15 to 20 will grenade that motor
DNTTRY is offline
post #11 of 12 Old 09-27-2012, 04:09 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
10 Will grenade A stock, tired 318.
BooSt Isn't Something You Play By Ear.
ratmonkey is offline
post #12 of 12 Old 09-27-2012, 04:49 PM Thread Starter
kheale1
1994 ZJ
lol I thank you for the concern, but my next upgrade is an Indy 415 stroker. I'm not too worried about this one. I'm just board and want something to do for now lol. I know I'll end up blowing her.. O well I guess.Hopefully I'm close to home!!
kheale1 is offline
Zj Turbo? Cjk76 ZJ Grand Cherokee Forum 69 12-16-2012 06:51 PM
how about a 318 turbo kit FST1994ZJ ZJ Grand Cherokee Forum 4 03-18-2010 11:32 PM
turbo thejeeper02 ZJ Grand Cherokee Forum 47 09-28-2006 06:19 PM
Turbo SRT-8 92blazn ZJ Grand Cherokee Forum 16 09-06-2006 04:26 PM
turbo the 5.9 spichman510 ZJ Grand Cherokee Forum 8 06-11-2003 09:12 PM
