Turbo 4.0l ZJ - Page 6 - JeepForum.com
 1Likes
post #76 of 627 Old 11-24-2011, 09:04 AM Thread Starter
TurboTPI
Originally Posted by PolkaPower
Purple people eater!
Yes it is! Hahaha
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #77 of 627 Old 11-24-2011, 05:42 PM
Noiitekk
That looks epic. It only took 4 hours?? Either it was a really easy install, or you're really good at what you do. I want
Noiitekk is offline
post #78 of 627 Old 11-24-2011, 09:39 PM
Hussler
1992 XJ Cherokee
Hmm pretty simple. Diverting the exhaust that way wont cause any issues?
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #79 of 627 Old 11-25-2011, 07:10 PM Thread Starter
TurboTPI
Yeah, it was pretty simple. So far no issues. It is alittle close to the upper control arm, but I think it will be fine. It might touch in extreme flex situations. We'll see.
TurboTPI is offline
post #80 of 627 Old 11-25-2011, 08:06 PM
theycallmesdz
that is sick man!!!!!!
theycallmesdz is offline
post #81 of 627 Old 12-03-2011, 12:37 PM Thread Starter
TurboTPI
Made a new charge tube. Looks alittle cleaner. I've been running it for a week now at 8lbs of boost. Still running good. I haven't done any real long wide open runs yet. It pulls hard tho for the 5-10 secs I've run it hard. I need a wide band o2 sensor before I do any long pulls. I drove 40 miles on the highway at 70-75mph and it seems to be better on gas when I'm not in boost. Also doesn't need to downshift nearly as much going up hills or overpasses.
TurboTPI is offline
post #82 of 627 Old 12-03-2011, 04:15 PM
AlphaLorde
That looks real nice!!
Great job
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #83 of 627 Old 12-03-2011, 05:27 PM
ZJ5point2GCL
Nice,
What size of turbo is that?
any plans of an intercooler?
do you have a blow off valve on it?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #84 of 627 Old 12-03-2011, 07:47 PM
aircruiser
aircruiser's Avatar
Does it fit alright with the hood closed? That was always an issue on my cherokee with a CAI and throttle body spacer.
aircruiser is offline
post #85 of 627 Old 12-04-2011, 02:46 PM Thread Starter
TurboTPI
The turbo is a t04e 57trim. I am planing on an Intercooler. It's not that important at the moment. It's just starting to get cold here in IL so I have some time to figure out an Intercooler. But by spring time I'm hoping to have one for sure. No BOV right now. The hood closes and the insulation doesn't even touch.
TurboTPI is offline
post #86 of 627 Old 12-04-2011, 03:26 PM
theycallmesdz
I am by no means a turbo expert, but I thought you had to have a BOV to expell excess boost.
Isnt this setup without the BOV a little dangerous?
post #87 of 627 Old 12-04-2011, 04:08 PM
badbird17x
badbird17x's Avatar
1994 ZJ
I would be very, very careful with no bov. My bov started to fail on my supercharged Hemi and it would stay wot for a second or 2 after letting off. Very unsafe. I would think with a turbo it would be deadly.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #88 of 627 Old 12-04-2011, 06:57 PM
jtackerman28
How long till it burns up haha
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #89 of 627 Old 12-04-2011, 08:27 PM Thread Starter
TurboTPI
Not dangerous at all. Superchargers have a bypass valve, it's different than a blow off valve. Superchargers spin in direct relation to rpm, so at 3,000 rpm it's flowing the same cfm of air regardless of throttle position, so a bypass valve relieves all that air if your under light throttle. Under light throttle, a turbo is not producing excessive air flow. Buick grand nationals, gmc typhoon/cyclones, among other turbocharged vehicles were not equipped with blow off valves from the factory.
TurboTPI is offline
post #90 of 627 Old 12-04-2011, 08:38 PM
jtackerman28
Those were bulit to take the boost
