Turbo 4.0l ZJ - JeepForum.com
 1Likes
post #1 of 622 Old 11-10-2011, 08:22 PM Thread Starter
TurboTPI
Turbo 4.0l ZJ
I am starting a project. I have a turbo on the way for my daily driver/weekend worrier ZJ. I have experience in turbo setups. The 4.0 has a strong bottom end and I'm going to push it. My thoughts are 5-7 lbs of boost on 93 octane. I'm going to do a fuel management unit at the ratio of 12:1. (12psi of fuel pressure to 1lb of boost) Photos will follow. Wish me luck. Lol. This will be a test of the 4.0l engine. Mind has 210,000 miles on it now. We will see how it holds up. It currently does not use any oil or leak any. And I take very good care of it maintenance wise.
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #2 of 622 Old 11-10-2011, 08:24 PM
KingtheZJ
this will be sweet! i want to see how it tuns out.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 622 Old 11-10-2011, 08:30 PM
Freestyle713
1994 ZJ
subscribed
Freestyle713 is offline
post #4 of 622 Old 11-10-2011, 08:31 PM
turbinetech2
1994 ZJ
Sounds like a cool project. My son will be talking my ear off when he hears somebody is turboing his 4.0l... Cmon, we can do that to your ZJ!! Keep us posted!
turbinetech2 is offline
post #5 of 622 Old 11-10-2011, 08:33 PM
zwzj4life
Originally Posted by Freestyle713 View Post
subscribed
x2 Should be interesting
ZwZj4Life
1995 Jeep Grand Cherokee Laredo (ZJ) / 4.0L I6 / D30 front, D35 rear / 3 Inch Boost / 31X10.50R15 BFGoodrich M/T
Zombie Outbreak Response Unit #313
zwzj4life is offline
post #6 of 622 Old 11-10-2011, 08:38 PM
1717pxcb
what will you be using to tune?
plan on running any meth/water injection?
what will you use to monitor everything?
any cats in the exhaust? (always been a fan of catless)
which turbo?
running an intercooler i assume?
i have no (read: absolutely 0) knowledge of turboing jeeps so will you have to do any work to the maf or will the stock maf work?
have you thought about an upgraded fuel pump or can the stock pump handle what you're after?
step colder plugs?
blah blah blah
1717pxcb is offline
post #7 of 622 Old 11-10-2011, 08:38 PM
96zj1987
I would like to see how this works out my plan was to build the block I just pulled and have my friend build it for boost. Unfortunately the rod shot through the wall of cyl #2 into #1 he currently holds the record for the worlds fastest eclipse spyder built the engine himself so I figured what the heck. I would like to see what you put down also consider meth should help out quite a bit. I know the 4.0 block can handle 1000hp+ so this should be interesting!
96zj1987 is offline
post #8 of 622 Old 11-10-2011, 08:53 PM
EfiniMotorsport
Turbo if you, or anyone else, is interested I have a few pics of turbo setups on the 4.0's. I was looking into this too but have too many other projects going on right now. If you haven't already you should check out 505 performance. They have done a few turbo and supercharged jeeps.
EfiniMotorsport is offline
post #9 of 622 Old 11-10-2011, 09:33 PM
1717pxcb
with an 8 cylinder, i'd supercharge, i think with the 6cyl you can go either way. (not because i know anything, but from what i've seen in the past - turbo 4 bangers and supercharged 8cyls)
really curious to see how this pans out.
efini, please post some pics and/or info on turbo builds - i was just thinking about this today - who has turbo'd their zj?
1717pxcb is offline
post #10 of 622 Old 11-10-2011, 09:58 PM
ZickJagger
My cousin built a turbo'd 4.0 but its a an XJ I believe. Its a Cherokee..Idk anything about them. He lives in Puerto Rico and I haven't gone to visit him, but he claims to have around 350hp and has a lot of other custom work done to it. If I can get some info and photos from him I'll get back to you.
ZickJagger is offline
post #11 of 622 Old 11-10-2011, 09:59 PM
ZickJagger
TurboTPI..I just realized you were in Bensenville. I'm in Vernon Hills. Depending on how this turbo build goes for you, would you be interested in doing another? :P
Screw that...wanna help with a lot of things? Such as...a lift...how about control arm bushings..can you change those out or no?
post #12 of 622 Old 11-11-2011, 01:03 AM
TheHalfWit
I plan on following this myself, best of luck to you. I'm planning on stroking mine next spring, but this also looks interesting enough to look into.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #13 of 622 Old 11-11-2011, 01:08 AM
Hussler
1992 XJ Cherokee
I would have turbo'd my 4.0 by now but every setup ive seen on the XJs was a total ***** for the builder, just plain old not enough space.
Always wanted to turbo something. Good luck!!!
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #14 of 622 Old 11-11-2011, 01:17 AM
JerzeyBoyWJ
2003 WJ
gonna be watching this one
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #15 of 622 Old 11-11-2011, 11:34 AM Thread Starter
TurboTPI
Thanks for wishing me luck. Haha. The Turbo I have is a t3/t4, 57 trim. Is supports about 450hp, obviously I will not be making near that, but it should do good on a 4.0l. I'm not intercooling it for now. Depending on how things go, I may add some type of intercooled later on. As for tuning it, the fuel management unit I'm getting should work fine. All it does is raise the fuel pressure with boost pressure. Quite simple. When I get the turbo (early next week) I will be working on the location of the turbo. As of now I'm thinking passenger side of the engine. Hopefully i will be able to keep the a/c. The a/c receiver/drier is gonna be tight tho.
TurboTPI is offline
