Tuning Options for OBD1 V8 - JeepForum.com
post #1 of 7 Old 09-11-2007, 11:19 AM Thread Starter
RebelW26GT
RebelW26GT's Avatar
So I now have a swapped in 360 in replace of the 318, but it seems to be a lil starved for fuel, what can I do to remedy this? Would I be able to just add on a fuel pressure regulator and bump up the pressure?
Stephen
95 ZJ
Engine: 6.0L Magnum
Trans: NV3500
T-Case: 231D
RebelW26GT is offline
post #2 of 7 Old 09-11-2007, 12:00 PM
rm2001wj
rm2001wj's Avatar
Your '95 318 fuel pressure regulator is an integral part of the fuel pump, so you can't just replace it with a different one. The '95 pressure is 35 psi. However, the pressure regulators on '96-'98 pumps produce a fuel pressure of 49 psi. If it would fit, and I don't know if it would, swapping in a later model pump/regulator might be what you need. The alternative would be slightly larger fuel injectors.
rm2001wj is offline
post #3 of 7 Old 09-11-2007, 12:45 PM Thread Starter
RebelW26GT
RebelW26GT's Avatar
is there anyone selling tuned proms for these?
Stephen
95 ZJ
Engine: 6.0L Magnum
Trans: NV3500
T-Case: 231D
post #4 of 7 Old 09-11-2007, 06:54 PM
t_guenther
I don't see why you couldn't just do a bypass and put in an inline fuel pump with a regulator if you want. I know people call it a swampy bypass, i haven't heard of anything wrong with it, plus you end up with a better pump.
Michigan Tech. Univ. - MET, Senior
--95 Grand Cherokee 5.2L V8--
Front/Rear Adj. Track Bar, 249 to 231 Swap, Tie rod conversion,
Hella 500's, Flowmaster 50 Series, Aussie Locker in the Rear,
31x10.5 BFG All-Terrains on 15x8 Pro Comp 97 Crawlers, 3" Lift
t_guenther is offline
post #5 of 7 Old 09-11-2007, 09:26 PM
impuresoul2k3
What about those with a stock 318 that want to do some tuning?
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #6 of 7 Old 09-11-2007, 11:14 PM Thread Starter
RebelW26GT
RebelW26GT's Avatar
I want a solution with more adjustability if possible. I was thinking about using the 96-98 Fuel Pump since it has a higher pressure output. 39psi vs 49psi I believe, so I think that might be the difference right there, but I'd like some more finite adjustability.
Stephen
95 ZJ
Engine: 6.0L Magnum
Trans: NV3500
T-Case: 231D
post #7 of 7 Old 09-12-2007, 08:02 AM
rm2001wj
rm2001wj's Avatar
You can probably add some adjustablility by using a MAP sensor adjuster. This is something that you can build yourself at little expense. They seem to work with OBD1 comuters, but OBD2 computers usually learn their way around them. Do a Google search for "map sensor adjuster".
rm2001wj is offline
OBD1 and OBD2 FDSJr ZJ Grand Cherokee Forum 30 06-05-2013 08:28 PM
OBD1 key on-key off technique? spikeystrip ZJ Grand Cherokee Forum 2 07-14-2009 01:29 PM
95 GC 5.2 can you test OBD1 spikeystrip ZJ Grand Cherokee Forum 1 07-09-2009 09:57 PM
03 4.0L Tuning tsconver ZJ Grand Cherokee Forum 1 12-21-2007 10:03 AM
1994 - OBD1 or OBDII ?? surfinmud ZJ Grand Cherokee Forum 2 10-24-2003 08:12 PM
