Tune-Up Questions - JeepForum.com
post #1 of 13 Old 02-27-2012, 08:53 PM Thread Starter
Bannerman53
Tune-Up Questions
Bannerman53 is offline
post #2 of 13 Old 02-27-2012, 09:30 PM
93CheepGC
have you done plugs, wires, cap, and rotor?
93CheepGC is offline
post #3 of 13 Old 02-29-2012, 07:34 PM Thread Starter
Bannerman53
Yeah I plan on doing spark plugs and distr. cap, but what wires and rotor(sorry, still learning).
post #4 of 13 Old 02-29-2012, 08:59 PM
jeepgoonie
2008 XK Commander
Wires are what connect your plugs to the distributor and the rotor is inside the distributor
Just Empty Every Pocket
jeepgoonie is offline
post #5 of 13 Old 02-29-2012, 11:40 PM
ngould1
Go get a can of seafoam. May not improve mileage but it will definitely keeps your engine running smoother. Plus it's fun watching all the smoke run out of the exhaust!
ngould1 is offline
post #6 of 13 Old 02-29-2012, 11:58 PM
samsonitesamson
Change the Inline Fuel Filter
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
post #7 of 13 Old 03-01-2012, 10:30 AM
PolkaPower
If he has a 96+ filter is in the tank. No need to change it unless the pump goes.
PolkaPower is offline
post #8 of 13 Old 03-01-2012, 12:29 PM
Technohead
My 96 has an inline filter. I think that was the last year?
I've always considered a new coil to be part of a tune-up.
-Eric
Technohead is offline
post #9 of 13 Old 03-01-2012, 12:35 PM
azgrandjeeper
Yea I just replaced my Plugs, wires, cap and rotor, ignition coil, TPS, cleaned my K&N filter, cleaned throttle body on my 98 5.2L. She runs so nice now.
azgrandjeeper is offline
post #10 of 13 Old 03-01-2012, 12:40 PM
PolkaPower
Good question. The more 95-96 ZJ's I see with different parts the more of a grey area it is between the new and old.
post #11 of 13 Old 03-01-2012, 12:44 PM
specia1k
Does replacing the distributor cap and rotor, really have an impact on MPG? I've done basically all that's been stated, with those exceptions. If so, which brand to replace with? Additionally, I've used Seafoam in the fuel, but never in the engine. Read thread to add seafoam to oil crank case ~100-200 miles before an oil change. Any downside to this? I change the oil every 5K miles and have since purchasing it new in '98.
2004 Jeep Grand Cherokee Limited 2x4 4.0L
2002 Jeep Grand Cherokee Sport 2x4 4.0L
1998 Jeep Grand Cherokee Laredo 2x4 4.0L
"Three daughters, three Jeeps"
specia1k is offline
post #12 of 13 Old 03-01-2012, 01:30 PM
LordHobbit
get brass terminals on cap and rotor. Brand doesn't matter so much. Stay away from aluminum terminals.
Think also about replacing o2 sensors. PM Kolak for some great parts and prices.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #13 of 13 Old 03-03-2012, 11:46 AM Thread Starter
Bannerman53
Thanks guys, this has been very helpful.
cleaning iac , mpg , tune up , Vacuum hose , vacuum leak
Tune-Up questions Peterson66 ZJ Grand Cherokee Forum 13 03-12-2011 12:54 AM
Exhaust and tune-up questions ZJcrawler45 ZJ Grand Cherokee Forum 4 10-09-2008 07:21 PM
tune up questions. 1997zj ZJ Grand Cherokee Forum 6 12-08-2006 03:37 PM
Brake and tune up questions eagleknight ZJ Grand Cherokee Forum 2 09-23-2006 06:05 PM
1994 ZJ - Tune Up Questions Blacula ZJ Grand Cherokee Forum 8 03-22-2006 11:35 AM
