Tune up on a 5.2/5.9. Any write up available? - JeepForum.com
post #1 of 5 Old 09-19-2013, 08:43 PM Thread Starter
ghost98
I did a search and didn't find anything. I just purchased a 98 5.9 Limited and I know it should be pretty easy but I was wanting to see if anyone knew of a write up on doing a full tune up on this engine. Plugs, wires, cap, rotor, and coil and anything else that may need to be changed. Thanks!!
ghost98 is offline
post #2 of 5 Old 09-19-2013, 08:58 PM
newfieZJ
Pretty straight forward . Make sure you get come compressed air around the plugs to blow out any debris caught around the plug . No need to get sand or whatever in the engine .
Use a brass cap and rotor , typically labelled premium parts in some stores . Stick to Champion plugs , I run double platinum's in mine and love them to bits . Most suggest just copper core . I personally like MSD coils . Oldest one I have is 5 years , perfect so far . I like their wires too .
No write up's on here for tune up's I have seen
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 5 Old 09-19-2013, 09:42 PM
PolkaPower
Make sure you route the plug wires according to the TSB. You don't have to have the wire holders mentioned. You can use holders/p;ug separators from the parts store and a little creative thinking. http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
PolkaPower is online now
post #4 of 5 Old 09-20-2013, 10:18 AM
Aceladriver
What newfie said, brass contact cap and rotor.
Nick/Kolak sells a good tune up kit, plugs, heavy duty wires and cap and rotor. He has the upgraded coil too if you need it - just be sure to get the little adapter harness with it. He should be in the vendor section I believe.
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline
post #5 of 5 Old 09-20-2013, 03:12 PM
Kolak
Vendor
Kolak's Avatar
Send me a PM here on the forum - happy to send you all the information about my Kolak Ignition kit.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
