tune up - JeepForum.com
post #1 of 9 Old 07-13-2005, 08:12 AM Thread Starter
bullet
tune up
need some quick advice.....im going to advanced auto parts this morning to get some tune up parts for my 5.9...it has 86k and i dont know if its ever had a tune up.....I was planning on doing wires, cap, rotor and plugs. any suggestions on what else to do or what parts to buy (looking for anything to increase performance).....I did some 1/4 mile runs in my jeep with the Gtechpro I keep in my other car (Honda S2000) and she was running 15.25 consistanly....im not sure if this is good for this jeep but its been alot of fun!!!!!!!!!
98 5.9 Limited Black- K&N FIPK -Custom made 2.5" Y pipe - 3" stainless exhaust with magnaflow cat and muffler - Sony HU 7715 - Infinity Perfects - 2 10" Audiobahns w/DEI amps -
more to come........
bullet is offline
post #2 of 9 Old 07-13-2005, 08:25 AM
dfwyatt
Don't forget a fuel filter, also buy yourself a can of seafoam and suck a third of the can through your brake booster vacuum line and dump the rest in the gas, that'll remove any carbon buildup in the cylinders or injectors.
1996 Jeep Grand Cherokee Ltd
5.2L 318 V8
dfwyatt is offline
post #3 of 9 Old 07-13-2005, 10:30 AM
starheimberger
just do it the, brand is not as important as doing it,just buy as good as oem or better
1948 willys 4x4 project pickup
starheimberger is offline
post #4 of 9 Old 07-13-2005, 10:49 AM
7thStranger
7thStranger's Avatar
Don't forget the air filter.
You may want to flush the radiator as well.
98 Grand Cherokee I6
7thStranger is offline
post #5 of 9 Old 07-13-2005, 05:07 PM Thread Starter
bullet
tune up parts
ok so i think im gonna go with accel 9000 8mm wires, accel cap and rotor, accel coil, and autolite platinum plugs (AP5224)....... I can get everything for around $180...what do you guys think?
bullet is offline
post #6 of 9 Old 07-13-2005, 06:05 PM
starheimberger
sumitt racing has an accel kit that was about 50 bucks for my 4.0 six should be adequate for a stock engine. you dont need super hi perf wires unless you use super hi output ignition system. simply overkill.
post #7 of 9 Old 07-13-2005, 06:54 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Don't worry about the fuel filter, it's in the tank and is cleaned every time you fill your tank up to the top. Jeep went to this set up in 96 possibly mid 96, the earlier have only an inline filter, (which I prefer).
Looks like you got the rest covered already.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #8 of 9 Old 07-14-2005, 04:34 PM Thread Starter
bullet
tune up
well i spoke with kolak yesterday and im considering his ignition upgrade...just cant determine if I should spend the $ (260) for it or just go with some decent wires, brass cap and rotor and autolite plugs for less than $100 bucks...this would free up some $ for the mopar performance ecu i want....does anyone think it would make a big difference to go with the better wires and msd coil or not...?
By the way Kolak is a great guy, very informative, and helpful....
bullet is offline
post #9 of 9 Old 07-14-2005, 06:10 PM Thread Starter
bullet
no advice?
anyone have an opinion on this?
bullet is offline
IL 6 Tune-Up cweb ZJ Grand Cherokee Forum 15 02-05-2010 03:06 PM
Bad Tune Up RFisher ZJ Grand Cherokee Forum 16 02-28-2006 04:06 PM
Tune Up? CaptainOats ZJ Grand Cherokee Forum 4 09-25-2005 06:27 PM
tune up Derek33 ZJ Grand Cherokee Forum 15 07-16-2005 10:09 PM
tune-up Derek33 ZJ Grand Cherokee Forum 8 03-24-2005 07:00 AM
