Tuffled 30 inch offroad bar - Page 2 - JeepForum.com
post #16 of 25 Old 08-16-2013, 09:22 PM
SDHarleydad
1994 ZJ
ok...too much for the living room. put them back on the ZJ
Casper
1994 JGC Laredo
SDHarleydad is offline
post #17 of 25 Old 08-17-2013, 02:02 AM
caseyliffick
Damn dude. Those things are bright as hell. Couple that with a nice set of fog lights and you're good for inclement weather, offroading or whatever swings your way.
caseyliffick is offline
post #18 of 25 Old 08-17-2013, 10:14 PM
SDHarleydad
1994 ZJ
update
ok mine is done.
Casper
1994 JGC Laredo
post #19 of 25 Old 08-19-2013, 12:04 PM Thread Starter
RagTagSoldier
Originally Posted by SDHarleydad
ok mine is done.
Where did you get your hitch tire carrier, or did you build it. I've been looking for somthing like that that I can still have access to the receiver
Sent from my iPhone using JeepForum so it probably looks goofy.
RagTagSoldier is offline
post #20 of 25 Old 08-20-2013, 07:18 PM
caseyliffick
Will you post pics of how you wired that up and your switch locations? Looks really clean.
post #21 of 25 Old 08-20-2013, 08:48 PM
SDHarleydad
1994 ZJ
I bought it off a guy with an XJ. I modified it a bit to tilt the tire in a bit. I think it is a homemade rig from the start
Casper
1994 JGC Laredo
post #22 of 25 Old 08-20-2013, 08:58 PM
SDHarleydad
1994 ZJ
The switch is just a simple panel of 4 switches. Fog,light bar,rear lights, and 12 volt socket. I ran the wires under the carpet to the rear to where the rear tail light is. drilled a hole out to the hatch (silicone) and ran it up and out the top into the rail. (No drilling the roof). Out the first hole to the cross bar. I used one of the rail mounting screws for the ground. I used a 4 pin trailer wiring plug so I can take the roof rack off.
Casper
1994 JGC Laredo
post #23 of 25 Old 08-20-2013, 11:04 PM
caseyliffick
Nice, it's not pinching that wire at all? Also, did you have to put any fuses or anything for it being that long? Did you pull straight off the battery?
post #24 of 25 Old 08-21-2013, 06:44 AM
SDHarleydad
1994 ZJ
no pinching, fused it inside(accessible). And yes I pulled the line from the battery.
Casper
1994 JGC Laredo
post #25 of 25 Old 09-08-2013, 12:16 PM
Dtperrell
Can you show how you wired you're light bar too? Im thinking about wiring up four offroad lights to my rack but i have no idea how im going to run the wires
2008 JK on 35's
Dtperrell is offline
