Ttransmission? growl - JeepForum.com
post #1 of 7 Old 12-22-2003, 07:37 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
I am having a problem with a transmission noise when shifting between P-R-N.
Everythings quiet in Park, Shift into Reverse and the growling starts, Shift into Neutral and it quiets some but is still there.
I only notice it when the jeep hasn't moved several hours. It could be warmed up for 20 minutes, but if it hasn't moved, it will make this noise.
I think it is in the Tranny- hard to tell from inside.
Anyone have any thoughts???
2Xtreme is online now
post #2 of 7 Old 12-22-2003, 07:55 PM
det69
I owned 2 full size Rams and both suffered from what you describe. All was fine providing the engine/tranny was warm but when cold you could hear the noise. The noise was also more pronounced when the outside temp dropped and seemed worse in reverse than in neutral. I just recently purchased my Grand Cherokee and upon reading the manual I noticed it uses the 42RE tranny....the same one my trucks used. A friend had the same problem in his truck and after about 50K or so he had to have the tranny rebuilt (covered by warranty). I sold/traded my vehicles before it got really bad so I really can't tell you what the exact problem was. I know this don't really help but check and see what model tranny you have and if it is the 42RE you can probably do a search and find info on the problem in a Ram truck forum.
det69 is offline
post #3 of 7 Old 12-23-2003, 05:15 PM
RockPaws
RockPaws's Avatar
My first thought is to check the transmission fluid level. After its warmed up with at least 20 min of driving. With the parking brake set and wheels chocked. Place in "neutral" and check fluid. it should be at the top of the hatched area or full. I have found simular problems due to low fluid level. I would normally find them 1qt or more low. Most of them checked the fluid in park position. In park position no fluid flows thru the valve body. In Neutral fluid flows thru the valve body and oil cooler.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #4 of 7 Old 12-23-2003, 08:01 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Thanks. I'll check it tomorrow and let you know what I find.
I had checked it recently, but as you said- in park
post #5 of 7 Old 12-23-2003, 11:49 PM
baseball_coach
You might want to go this website and see if this discribes your problem. http://dodgeram.info/tsb/2000/21-01-00.htm
baseball_coach is offline
post #6 of 7 Old 12-24-2003, 10:07 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Well I checked the fluid- Tranny warmed, in neutral- and all is well.
Fluid level is dead center between the two "Hot" holes.
Any other thoughts??
post #7 of 7 Old 01-01-2004, 06:17 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Anyone else have any thoughts?
Growl underneith over 55mph MeWJWifeZJ ZJ Grand Cherokee Forum 8 10-15-2008 09:30 PM
Audible Growl from engine? swataz ZJ Grand Cherokee Forum 4 12-16-2007 11:06 AM
98 JGC Ltd engine growl noise abc32453 ZJ Grand Cherokee Forum 7 08-27-2007 10:20 AM
Growl On Turn JERSEYJOE ZJ Grand Cherokee Forum 2 05-12-2005 08:12 AM
Front End noise/growl rmckenna ZJ Grand Cherokee Forum 12 06-27-2004 01:34 AM
