TSB question for original 97 ZJ owners. (Past or Present)
#1 | |
Question for original owners. I found a list of TSB's on these GC's. Since I own one of these now. I'd like to know how many of you got a bulletin about all these problems and if you did anything about them? Just wondering the chances of my jeeps first owner taking care of all these TSB's. Thanks
Technical Service Bulletin Titles for 1997 JEEP GRAND CHEROKEE 4WD 8 Cylinders 318 Y 5.2L MFI Occasionally, the manufacturer of your vehicle will issue technical service bulletins (TSBs) about your vehicle that change the servicing instruction in your owner's manual. Please don't ignore TSBs - they contain timely service information that must be followed by anyone who services your vehicle. Title Number Date PCM - Erroneous MIL, and/or Driveability Concerns 182696 09/27/96 Body Control Module - Check Sum Error Fault 083196 09/27/96 Brakes - Noise Explanation 050996 10/14/96 A/C Heater - Mode Change to Defrost During Acceleration 240196A 10/18/96 A/T - Quick Connect Removal & Reconnect Procedure 211596 11/08/96 Paint - Fallout Damage Repair 236996 11/22/96 Service Manual - Description of Revisions And Changes 26-12-96 12/01/96 Windshield - Difficult Urethane Primer Removal 23-75-96 12/27/96 Service Manual - Description of Changes 26-01-97 01/01/97 PCM - Wire Harness Connector Repair Package 080197 02/03/97 Black Plastic Body Components - Chalky Residue 23-03-97 02/14/97 Air Bag - Warning Label Requirements 08-09-97 02/28/97 Transfer Case Shifter - Thumping/Bumping Noise 210297 03/07/97 PCM - Erroneous MIL ON/Driveability Improvements 181297 03/14/97 A/T - Cold Weather Trans Cooler Bypass Kit 210697 03/21/97 A/T Cooler - Reverse Flush With Bypass Kit Installed 210797 03/21/97 Roof/Sun Roof - Water Leaks 231497 04/04/97 Windshield Area - Wind Noise 231797 04/04/97 Leak Detection Pump - Dealer Test Mode 18-17-97 05/02/97 A/C - Cycles to OFF When Ignition Is Turned OFF 24-07-97 05/09/97 Engine - Coolant Recommendations 07-03-97 05/09/97 08-19-97 - 05/09/97 08-19-97 05/09/97 Garage Door Opener - Rolling Code Information 08-20-97 05/16/97 Service Manual - Revisions, Description of Changes 26-06-97 06/01/97 Tire & Wheel - Runout 22-01-97 06/13/97 Service Manual - Description of Revisions 26-07-97 07/01/97 Rear Door Speaker - Buzz 23-35-97A 07/11/97 Transfer Case Shifter - Thumping/Creaking Noise 21-02-97A 07/11/97 A/C Evaporator - Emits Odors 24-11-97 07/11/97 CD Player - Inoperative 08-27-97 07/18/97 Fuel Gauge - Inaccurate 08-19-97A 07/25/97 Liftgate Ajar Switch - Terminal Corrosion 08-28-97 09/08/97 Roof/Sunroof - Water Leaks 23-14-97A 09/12/97 Airbag - NHTSA Authorized Deactivation 08-32-97 09/19/97 Door Locks - Cycle When Rear Defogger is Turned Off 08-34-97 09/19/97 Radio/CD Player - Inoperative 08-27-97A 09/26/97 Door Check Roller - Worn/Broken/Missing 23-53-97 10/03/97 Engine - High Driveability Index Fuels 14-08-97 11/21/97 RKE Transmitter - Premature Battery Failure 08-39-97 11/28/97 A/T - Overdrive Unavailable in Cold Temperatures 21-06-97A 12/19/97 Horn Switch - Service 08-42-97 12/31/97 Evaporator/Cowl Screen - Revision 24-17-97 12/31/97 Doors/Locks - Inoperative/Binding 23-03-98 01/30/98 Heater A/C Housing - Service 24-02-98 03/13/98 Rear Window Wiper - Operation 08-08-98 03/13/98 Front Brakes - One Click on Initial Application 05-02-98 03/13/98 Brakes - Pedal Pulsation 05-03-98 04/03/98 A/T - Engine Bucking/Surging at 5,300 Rpm 18-19-98 04/10/98 Radio Transmitting Equipment - Installation 08-16-98 04/17/98 Fuel Pressure Gauge Adapter - Usage 14-03-98 05/01/98 ABS - Connector Repair 08-19-98 05/08/98 Powertrain Control Module - Service Precaution 18-21-98 06/05/98 Auto Computers - Y2K Effects 08-36-98 07/24/98 Rear Axle - Carrier Bearing Growl 03-03-98 07/31/98 PCM - Light Spark Knock Condition 18-24-98 07/31/98 Transfer Case Shifter - Creaking/Thumping Noise 21-09-98 07/31/98 LDP - MIL ON, DTC P1494 Set 18-27-98 08/21/98 Front Brakes - Pedal Pulsation 05-03-98A 08/28/98 Airbag - ON/OFF Switches Availability 08-17-98B 09/18/98 PCM - Flash Programming Failure Recovery 18-32-98 09/25/98 I/M Testing - OBDII CARB Readiness Monitor Information 25-02-98 10/23/98 Sun Roof - Inoperative/Stuck 23-54-98 11/06/98 Radio/CD Player - Erratic Channel/Track Changes 08-50-98 11/27/98 Memory Power Seat - Travel Range 08-44-98 12/11/98 Air Bag System - ON-OFF Switch Availibility 08-17-98C 12/30/98 Ignition System - Cross Fire/Ignition Wire Induction 18-48-98 12/30/98 Heated Seat - Inoperative 08-03-99 02/05/99 A/T - Buzz/Whining in Reverse When Cold 21-08-99 04/30/99 Power Distribution Center - Service 08-07-99 05/12/99 Leak Detection Pump - Monitor Test 18-12-99 06/18/99 Radio Communication Equipment - Recommendations 08-23-99 07/09/99 Front End Alignment - Adjustable/Offset Ball Joints 02-12-99 08/20/99 Child Seat Tether Anchor - Parts/Labor Identification 23-35-99 09/03/99 Child Seat Tether Anchor - Labor/Parts Identification 23-35-99A 10/01/99 Engine - Spark Knock/Excessive Oil Consumption 09-06-99 10/10/99 Airbag - On/Off Switch Availability 08-37-99 11/12/99 Front Hub Seals - Grease Purge Explanation 02-06-99A 12/17/99 Electrical - Wire Splice Procedure Revision 08-06-00 02/25/00 Engine - Spark Knock/Oil Consumption 09-05-00 02/25/00 Child Seat - Tether Anchor Installation 23-08-00 03/03/00 CD Player - CD Compatibility 08-11-00 03/24/00 18-05-00A - 06/23/2000 18-05-00A 06/23/00 MIL ON, Erroneous DTC P0107 Set 18-08-00 06/23/00 TCM - MIL ON/DTC P1763 Set 21-04-00 06/30/00 Child Seat Tether Anchors - Parts/Labor Identification 23-08-00A 07/07/00 Child Seat - Tether Anchor Part Numbers & Labor Time 23-008-00B 11/24/00 Outside Mirror - Glass Replacement 23-034-00A 12/15/00 Wiring - Revised Splicing Procedure 08-006-00A 12/29/00 PCM - MIL ON/Erroneous DTC P1398 (or $BA) 25-003-01 02/23/01 Evaporative System - Leak & DTC Diagnostics 25-004-01 05/11/01 Airbag/Clock Spring - Service 08-010-01 05/25/01 Generic Scan Tool - Reference Information 18-012-01 05/25/01 A/T - Fluid Usage 21-006-01 06/29/01 Outside Rearview Mirror Glass - Replacement 23-027-01 09/21/01 Driver Airbag - Trim Cover Service 19-009-01 10/26/01 Air Bag - On/Off Switches 08-025-01 11/23/01 Outside Rearview Mirror - Glass Replacement 23-015-02 04/01/02
1997 Jeep Grand Cherokee LMTD Loaded 5.2 V8 Q-Trac 4X4 |
#2 |
As Seen on TV
double post
#3 |
As Seen on TV
Well, I don't own a 97 ZJ and I'm not the original owner of my ZJ, but I don't think the manufacturer has to alert owners about TSBs, just recalls. If you want to know about recalls, the dealer can check to see if there are any incomplete recalls for your vehicle. Actually, I think you can do it yourself through the Jeep website as well.
Remember too that many of these are for information only--there's no fix, it just acknowledges that owners have reported the problem, noise, etc. For example, the engine coolant one you have listed or the service manual updates. The others do have an actual fix for them, but unless you are having a specific problem that relates to one of these TSBs, I wouldn't really worry about whether they've been done or not. |
#4 |
Ok thanks.
#5 |
sorry to bring up an old thread. i noticed that there was a tsb for the heated seats failing. would i be able to go to the dealer and have this fixed on there dime even though i am not the original owner or am I sol?
98 limited 5.9ltr stock 2.5" exhaust flowmaster |
#6 |
someone told me you can do it within 10 years, doesnt matter you arent first owner, but it may vary from manufacturer
I have a modified 1999 WJ and a stock 2001 WJ Tread Lightly Pictures PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! ! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
