Trying to understand 5 speed PCM swap options - JeepForum.com
post #1 of 4 Old 01-28-2014, 01:19 PM Thread Starter
urbex
It's been about a year since I put it together, and now I'm finally getting around to cleaning up the install, part of which is deciding what to do about the PCM.
I've read countless threads on here and other forums, and am still slightly unsure of what I need to get/do. I understand that I should be able to plug in a PCM from a similar year Ram or Dakota with the 318 and manual trans, but then I also see the scores of "for some unknown reason, Chrysler PCMs seem to go bad from just sitting on the shelf", which as an electronics tech makes absolutely no sense to me. Then I read that some PCMs are married to the SKIM module, which will cause a no start condition if swapped into another vehicle, which I suspect is the reason some of these PCMs seem to go bad.
But then it also appears that '97 is the year that these SKIM computers started appearing. I'm also making the assumption that same year PCMs should be able to communicate with my existing gauges OK. So if I get a '96 PCM to match my '96 Jeep, the SKIM and gauges shouldn't be a concern to me.
But that still leaves the issue of potential cruise control problems, and factory immobilizer/alarm problems. If I lose the factory immobolizer/alarm, that's really not an issue to me. I already have other passive and active kill switches in the Jeep, and since the factory keyfobs died a long time ago, it's really more of an annoyance now. Losing cruise would kind of suck though.
Is there a way to tell which PCM I would need based on part number? Or another way to tell?
There's also another kicker for me - I would need to get whatever I get flashed with my current VIN for emissions (yep, already called the emissions dept, was told a VIN mismatch would be an instant fail). Which makes me wonder if my better option would be to send my current PCM off to some place like B&G, though I don't need any of the performance tuning done.
urbex is offline
post #2 of 4 Old 01-28-2014, 02:28 PM
Oldfrog
2007 WK
Dont know the entire answer, but as far as I know, the PCM doesnt need to be flashed. I've installed 4 in my 97 and never had to flash any of them. (a bad o2 sensor was taking them out, is my theory) The VIN isnt stored in the PCM on the 97 and I think 96-98 PCMs are all the same.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 4 Old 01-28-2014, 02:47 PM Thread Starter
urbex
Oooh...much helpful there! I was under the impression that ALL OBD-II computers had the VIN flashed in them, regardless of make/model, thus the concern for emissions testing time when they jack into the computer.
EDIT: Started a different tack in my Googling, and found a thread on another forum for Mass emissions testing that sounds similar to the way Arizona does it - they just jack into the diagnostics port, and run a code scan. If there are no active codes, you pass, and at least for their system, even if the VIN was flashed in the PCM they don't have a way to verify it. That doesn't come into play until 2000 when the CAN-BUS stuff started getting used. They also mentioned that although B&G can strip the auto trans programming, and change the VIN, they still consider it a custom tune with a $430 cost (I did call B&G earlier, had to leave a message for the tech...still waiting on a call back). Ouch.
urbex is offline
post #4 of 4 Old 01-28-2014, 03:27 PM
970001zj
dakota or ram manual transmission ecu but someone will
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
