trying to make up my mind - JeepForum.com
post #1 of 11 Old 01-13-2014, 11:16 PM Thread Starter
mr4x4
I've been thinking of buying Clayton front long arms and getting rid of the iron rock front long arms I have Claytons long arms in the rear
Just so you understand my iron rock front long arms around for the zj I have the xj front dana30 and it's maxed out for the alignment so I really need to buy the xj long arm
If i buy the claytons i can not only match my rear long arm kit i can adjust my front axle and push it forward about an inch for the bigger tires and possibly install my headers and if I ever change axles the front long arms will work
so should i spent the $1200 on the front Clayton long arms and new skid or $300 on the iron rock xj long arm and spend the money on other things
If I do go the claytons route i will sell the iron rock long arms and skid
94 stock zj and a 95 zj with a 5.5" lift with 35" bfg km2 a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 super30 kit arb 4.1 low range transfercase
mr4x4 is offline
post #2 of 11 Old 01-13-2014, 11:19 PM
WhiteOut
WhiteOut's Avatar
Easy. Claytons.
WhiteOut is offline
post #3 of 11 Old 01-14-2014, 03:00 AM Thread Starter
mr4x4
I guess I'm buying the claytons kit
mr4x4 is offline
post #4 of 11 Old 01-14-2014, 04:21 AM
newfieZJ
You could go cheap and just modify the long arm to accommodate , I did . I had to shorten the upper link .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #5 of 11 Old 01-14-2014, 05:55 AM
Myusername1674
If you do go clayton and are interested in selling your old iron rock front let me know
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #6 of 11 Old 01-14-2014, 06:08 AM
Technohead
This is a no-brainer.
-Eric
Technohead is offline
post #7 of 11 Old 01-14-2014, 03:10 PM
speedbucket
Are you welding Clayton's on or having someone else do it?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #8 of 11 Old 01-14-2014, 09:00 PM Thread Starter
mr4x4
I'm welding it
mr4x4 is offline
post #9 of 11 Old 01-14-2014, 09:03 PM Thread Starter
mr4x4
Originally Posted by Myusername1674 View Post
If you do go clayton and are interested in selling your old iron rock me know
I will be selling the old iron rock arms skid plate and crossmember probably with new bushings and the rebuild stuff for the joints
mr4x4 is offline
post #10 of 11 Old 01-15-2014, 08:30 AM
Myusername1674
Okay well let me know if you do, just shoot me a pm
(in progress)
post #11 of 11 Old 01-15-2014, 08:58 AM
speedbucket
I'm welding it
Cool. Just a little curious as to why you wouldn't just build your own front or modify the iron rock setup
