Trying to fit mud tires on my Grand.. - JeepForum.com
post #1 of 13 Old 11-10-2013, 05:54 PM Thread Starter
i6zombiejeep
Well, I found some cool looking rims for my 98 Jeep. They are 15x10s, and I would like to run 31s. A 31/12.5 tire would be okay for this wide of rim, right? I keep seeing posts that you need at least 33s, but I can't fit those.. lol what is the metric equivalent for this size? Any help is greatly appreciated!!! Thanks,
Jeff
i6zombiejeep is offline
post #2 of 13 Old 11-10-2013, 06:07 PM
Technohead
Find some 8"-8.5" rims. 10" is too wide.
-Eric
Technohead is offline
post #3 of 13 Old 11-10-2013, 06:17 PM Thread Starter
i6zombiejeep
Thanks for the quick reply, and yeah, that's what I keep seeing is to just get different rims. But I like the offset so that they'll stick out and give the Jeep a little stance. They are really wide, but I want to take advantage of them because I am building on a college student budget...
post #4 of 13 Old 11-10-2013, 07:28 PM
WhiteOut
WhiteOut's Avatar
If you run a 12.5" wide tire on a 10" wide rim, don't bother airing down since you'll just pop a bead. You'll probably rub control arms as well depending on the backspacing on the rims.
Sent from AutoGuide.com App
WhiteOut is offline
post #5 of 13 Old 11-11-2013, 06:59 AM
PolkaPower
The tire maybe 12.5 at the tread but it gets skinnier at the bead. 10" is too wide. Get an 8" rim with 3.75-4" of B.S.
PolkaPower is online now
post #6 of 13 Old 11-11-2013, 07:41 AM
slprwgn
i am running 12 inch wide wheels with 3.5 backspacing... now im not a street rig but i have no issues out of them, no rubbing, and i run a 15 inch wide tire on them.... as for 12.5 too wide for 10 inch wide rim, no way... it will run just fine on that wheel, i have plenty of friends running that 12 and 13 inch wide on 10 inch wheels...
i agree on the mean stance look, i think it will look awesome
slprwgn is offline
post #7 of 13 Old 11-11-2013, 09:57 AM
PolkaPower
It's not an opinion, it's a fact that a 12.50" wide tire on an 8" rim will hold a bead better, perform off road better when aired down(not spinning on the rim), and the tire will wear better than on a 10" rim.
What looks better is debatable.
http://www.pirate4x4.com/forum/jeep-...rim-width.html
post #8 of 13 Old 11-11-2013, 11:23 AM Thread Starter
i6zombiejeep
Well shoot. I'll begin my search for some narrower rims.. Thank you guys for the replies, and it makes sense. I was worried that the bead would have a hard time holding. This Jeep is going to see a lot of snow, and therefore a lot of airing down. I realllllyyyyy want some of those AEV wheels. They look sweet!
post #9 of 13 Old 11-11-2013, 05:41 PM
zjilla
Are they airing down? Using beadlocks? Or wheeling at 30+psi?
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #10 of 13 Old 11-12-2013, 12:32 AM Thread Starter
i6zombiejeep
Beadlocks are no good for highway use, correct? How exactly do beadlock rims work?
post #11 of 13 Old 11-12-2013, 02:27 AM
kg6mov
Hears the voices
kg6mov's Avatar
Internal beadlocks like the hummer h1 rim are legal for highway use, external beadlocks like most offroad wheels are not. They will perform fine on the highway but the failure mode of the rim involves the tire trying to pass the jeep, which is unadvisable.
kg6mov is offline
post #12 of 13 Old 11-12-2013, 09:10 AM
WhiteOut
WhiteOut's Avatar
What law the bans the use of beadlock wheels on highways? (Not inspection rules and no "DOT Certified" stuff)
Failure of a non-beadlock wheel will produce the same effect.
WhiteOut is offline
post #13 of 13 Old 11-12-2013, 09:19 AM
PolkaPower
They would not pass inspection in this god forsaken state for sure.
http://www.liftlaws.com/are_beadlocks_street_legal.htm
15x10 , rim size , tires
