Trunk Latch - JeepForum.com
post #1 of 3 Old 12-29-2002, 06:50 PM Thread Starter
ZJGuido
Junior Member
ZJGuido's Avatar
Trunk Latch
Here's the problem. Today my father went to open the trunk of my jeep and as he was pulling on the handle, he hears a snapping noise. The trunk opened but, like a dummy, he closed it again. Now it's stuck closed. Common sense tells me that its the trunk latch. Would anybody know how i can get it to open or get to the latch from the inside?
Thanx
1998 Platinum ZJ 5.9 Limited
K&N FIPK / MOPAR ECU / Bilstein Shocks / H&R springs / Addco sway bars
ZJGuido is offline
post #2 of 3 Old 12-29-2002, 07:01 PM
MJR
MJR's Avatar
1988
The adjustable handle rod proably came off. Pull the top of the hatch trim panel back (four screws) from inside and reach down to pull the rod to open the hatch. Then you can pull the whole panel off to fix it. Sometimes the metal clip needs to be bent a little tighter for a better fit. Adjust the rod where the handle feels the best.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 3 Old 12-30-2002, 09:35 AM
AHG
The same thing happened to me a while back. MJR's reply is pretty much what worked for me. ive had no problem since.
AHG is offline
Grande Cherokee door latch will not latch arory1@shaw.ca ZJ Grand Cherokee Forum 14 02-25-2015 09:36 AM
Trunk latch hydrolic pump help jhopkinslx4 ZJ Grand Cherokee Forum 9 03-25-2009 04:28 PM
GC door latch, wont latch arory1@shaw.ca ZJ Grand Cherokee Forum 0 03-02-2009 08:33 AM
New Trunk shocks for ZJ??? Gabe ZJ Grand Cherokee Forum 12 02-01-2007 03:02 PM
Loose trunk lid? Derek33 ZJ Grand Cherokee Forum 5 03-13-2005 12:24 PM
