Is it true trannies won't shift into OD when too cold? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Is it true trannies won't shift into OD when too cold?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-07-2010, 07:22 PM   #1
crashcraddock
I think I've read this once upon a time. This problem is getting old, my WJ takes forever to shift into OD when it's cold outside. I'm OK in the morning because the Jeep stays in the garage, but at lunch or after work I can go 10 miles on the intersate before it finally shifts in to OD. I'm not doing any damage because of this am I?
crashcraddock is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 07:34 PM   #2
WahooCreek
I am having the same issue with my 2000 wj, and like yours, mine will not kick into OD until about 8 miles or so. No answers for you. Just wanted to let you know there's another one out there with the exact same problem.
WahooCreek is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 07:35 PM   #3
02Lightning
I think it's 30 deg. before it will shift but it should get to that temp in less than a mile?
1995 Jeep Grand Cherokee Limited 4.0L NP249 Transfer Case, 42RE, 212,000 miles
02Lightning is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 07:42 PM   #4
GrandLaredoWJ
Mine does this same thing here in MN, (Right now 8 below zero), I usually have to drive for about 5 miles or so before it shifts. The reason for this is because when it is cold out the transmission fluid gets thicker.
Therefore making it harder for the transmission to pump it through to get it into overdrive until the fluid is warmed up enough. And no, you are not doing any damage to your transmission because of this, no worries.
'00 Grand Cherokee/Rally Jeep-Ojibwe Forests Rally Heavy Sweep #95 -4" Teraflex Lift, Homemade Adj. Longarms, 33x10.50 BFG All Terrains, 4.2L built, bored, blueprinted & balanced, Lots more..
Red Jeep Club Member #499
MN Jeeper #48
Black '75 CJ5- Built 304, 4.88's, Dana 44 Spooled, Dana 30 Spooled, 4" lift, 35x12.50 tires
GrandLaredoWJ is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 07:45 PM   #5
GrandLaredoWJ
Also forgot about that, that is correct. but mine needs to get to WAY more than 30 degrees before it shifts.
MN Jeeper #48
Unread 01-07-2010, 07:54 PM   #6
crashcraddock
I should mention my wife's 00 WJ V8 has Royal Purple tranny fluid in it and it hardly ever has this problem, only when it sits outside for a whole day. My 99 WJ V8 has Valvoline ATF in it and it experiences this problem more frequently.
Unread 01-07-2010, 08:01 PM   #7
comptiger5000
It could be based partly on pressure as well, so that if it determines the fluid is too thick via temp or pressure, it won't shift to OD. My suggestion is to warm it up in Neutral with the E-brake on (as long as it's on mostly flat ground and the E-brake works). That will allow fluid flow through the tranny (and the cooler in the radiator), so it will start to warm up a little before you start driving.
comptiger5000 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 08:05 PM   #8
crashcraddock
Sounds like a plan to me.
Unread 01-07-2010, 08:24 PM   #9
Falkon
In the original owner's manual for my 2004 Limited, it states that the trans will not shift into overdrive til it warms up. Perfectly normal. Mine does this also.
Falkon is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 10:19 PM   #10
JesseOR
It is normal. Its in all owners manual. Its not the operating temp of the engine, its the temp of the trans.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline   Reply With Quote Quick reply to this message
