Trouble with LED's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Trouble with LED's
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-14-2005, 10:18 AM   #1
bsm413
Trouble with LED's
I've replaced all my interior and exterior lighting w/ Polarg M series Hyper White Bulbs. Unfortunately they don't make a 3157 size bulb that replaces the front parking light / turn signal bulb. I've tried other types and they're just not bright enough - they look too yellow. I recently attempted to replace them w/ LED's, but when the blinker was activated it blinked extremely fast and then burnt out the fuse. These were the only bulbs that actually looked the way I wanted them to. Looking for any insight on why these LED's weren't compatible. Does anyone have LED"s installed on their Jeeps? Thanks
[B][SIZE=2]2003 Laredo 4.7L V8[/B][/SIZE]
[COLOR=White]Kolak 3" Exhaust[/COLOR]
[COLOR=White]K&N Gen II FIPK[/COLOR]
[COLOR=White]Mopar Tubular Side Rails[/COLOR]
[COLOR=White]Mopar Rear Air Defelctor[/COLOR]
[COLOR=White]Westin Safari Bar[/COLOR]
[COLOR=White]Hella 500 Fogs[/COLOR]
[COLOR=White]Hella Halo / Angel Eye Fogs[/COLOR]
[URL=http://www.cardomain.com/member_pages/view_page.pl?page_id=810209][CLICK HERE] Visit My Cardomain Page [CLICK HERE][/URL]
bsm413 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2005, 04:32 PM   #2
justjeepin
Its a resistance thing. The LEDs have a much lower resistance than the regular bulbs do. Meaning more current flow (blown fuse) and usually some type of indicator either on the info system or the fast blinking indicating the bubl is bad. If you really want the LEDs to work, the only method I know of is measuring the factory bulbs resistance then the LEDs, find that difference and put that amount inline of the wireing for the LEDs. I believe you will have to do this for each LED you put in. I have only seen it done but have never done it myself. Too much work for the small benifit to me personally. Hope this helps
'98 5.2L
All stock stuff but soon to be upgraded.
justjeepin is offline   Reply With Quote Quick reply to this message
Unread 03-14-2005, 04:40 PM   #3
greasefingers
1994 ZJ
justjeepin: you are correct about the ohms being the same. Some LEDs come with resistors built into them, otherwise you must add them.
This site is cool:
http://superlumination.com/7443_7440.htm
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote Quick reply to this message
Unread 03-14-2005, 07:24 PM   #4
nashmd454
I tried the same thing and just didn't like the brightness at all. I went back to new bulbs. But justjeepin is correct with the resistors. I got my leds from that same superlumination link. There is another link in a different thread ....saw it yesterday....and they even said what would happen and you would need resistors and all the safety warnings and so on....I will see if I can find that link and post it here.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2005, 10:20 PM   #5
bsm413
That would great; I would like to read up on it a little bit more. The weird thing about it is that the reverse lights take the same bulb and I replaced them no problem with a pair of the Polrg M series. For some reason they won't click in to the front ones.
