With trimming is 35s possible with iro la? - JeepForum.com
post #1 of 17 Old 05-05-2009, 05:21 PM Thread Starter
normes
I have IRO front long arms want to go to a bigger tire soon. my question is with enough trimming can I make it work or with them not being able to be lenghtened is that to much?
35" BFG KM2 6.5 x 5.5 IRO springs HC longarms, 242 swap, 40 series, custom dis., Hellas, Custom front bumper
normes is offline
post #2 of 17 Old 05-06-2009, 12:04 PM Thread Starter
normes
I guess it has never been tryed or no one knows.
normes is offline
post #3 of 17 Old 05-06-2009, 12:05 PM
CLNinja
CLNinja's Avatar
i dont know about the WJ system but with the ZJ system we can fit up to 37s easily
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #4 of 17 Old 05-06-2009, 12:26 PM
alexsious
judging by your lift, you shouldn't have much issue with getting 35's.
alexsious is offline
post #5 of 17 Old 05-06-2009, 12:30 PM
soccerfreak3377
you shouldnt have problems fitting 35s at all
4.5" Lift, 33" BFG KM1, 15x8 Black steelies, RE adjustable trackbars, IRO Sway Bar Links, Pro Comp SS, K&N Intake, Prerunner Front Bumper, Flowmaster Super 44 with turn down, Cobra CB + PA
soccerfreak3377 is offline
post #6 of 17 Old 05-06-2009, 12:35 PM Thread Starter
normes
nice
thanks
normes is offline
post #7 of 17 Old 05-06-2009, 01:12 PM
MoonyJohn
MoonyJohn's Avatar
Remember, when going from 32's to 35's, your axles will need to be beefed up and you will need to regear. You have the v8 so power wont be an issue, but if you want to keep the close to stock power, Id highly recommend regearing to 4.56.
MoonyJohn is offline
post #8 of 17 Old 05-06-2009, 01:21 PM
soccerfreak3377
DEFINITELY should regear. you dont want to be running 35s on stock gears at all
post #9 of 17 Old 05-06-2009, 07:05 PM
trailblazr81
And while your in there swapping gears a locker or 2 would be a good idea!
1996 ZJ, 318, F>R, no sways, CAI, Glasspack Exhaust, 265/75/16 Muds
trailblazr81 is offline
post #10 of 17 Old 05-06-2009, 07:10 PM
GraKee99
Rapist Wit
GraKee99's Avatar
If you don't have rear adj. arms, you will probably need to get them.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #11 of 17 Old 05-06-2009, 08:04 PM
horatio102
I'm running 33s on the IRO long arms, and I'm pretty close to rubbing in some unfortunate spots. I need to take the BFH to the pinch weld in the front wheel wells, and do some more cutting.
horatio102 is offline
post #12 of 17 Old 05-07-2009, 12:46 PM Thread Starter
normes
Ya rear controls are a deffent along with some type of adj. upper rears. And regearing is on the to do list as well and I haven't decided on 4.10s or 4.56 probably go with the bigger one but not sure.
normes is offline
post #13 of 17 Old 05-07-2009, 12:49 PM
horatio102
When I get around to re-gearing, it's most likely going to be to 4.88s. With 33s and the 545rfe reflash, highway mileage should be around 15 still, but it'll help the crawl ratio as well as pick up some more power for pulling hills. 3.73s are stupid, and I hate them. They're fine on the 02 with stock tires, but the 99 with 33s make me want to stomp babies.
post #14 of 17 Old 05-07-2009, 02:54 PM
skain8
skain8's Avatar
Since the IRO long arms are not adjustable, you will likely have to trim/cut moreso than say with Clayton's b/c you can't push your axle any farther forward. Still, it certainly can be done with trimming.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is online now
post #15 of 17 Old 05-07-2009, 04:42 PM
nelson1248
ya should fit easily i have 32s on a BB so definitely will fit.
MOPAR or NO CAR
nelson1248 is offline
trimming nuey302 ZJ Grand Cherokee Forum 5 11-15-2009 04:21 PM
Serious trimming help. Ubergrob ZJ Grand Cherokee Forum 3 05-16-2009 08:45 PM
Trimming on a WJ Pbux690 ZJ Grand Cherokee Forum 1 01-13-2009 12:44 PM
33s to 35s and some trimming Texas ZJ1 ZJ Grand Cherokee Forum 41 04-12-2007 12:01 PM
trimming jeep1212 ZJ Grand Cherokee Forum 1 11-11-2004 09:45 AM
