tried out my new spare key and the jeep dies - Page 2 - JeepForum.com
post #16 of 27 Old 09-29-2009, 08:15 AM
Redrum_1
Some of your better hardware stores have transponder blanks and can fix you up for about $30. I didn't know this till after ordering one from ebay. When I went in to get it cut he told me they had them and can also program them just like a dealer can.
Good Luck...
2013 Dodge Ram 1500 Express Quad Cab. 5.7L Hemi 6 speed automatic 3:55 gears LSD with 20 inch rubber
2000 Jeep Grand Cherokee Limited 4.0L
2003 Nissan 350Z Enthusiast Model 6 speed manual
2002 Audi A6 Avant Quattro 3.0L Auto
Redrum_1 is offline
post #17 of 27 Old 09-29-2009, 10:25 AM
mrtosh
2005 WK
^^^^interesting. Anybody try said hardware store version? Are we talking like Home Depot?
'05 WK Limited QDII, Superlift 6", Bilstein struts,315/70/17 Duratracs, Gibson CB, Volant CAI, JBA UCA's, JKS quick disco, adj. Rear trac bar, 4xguard armor, Diablosport Intune, Xenondepot 6000k HID's, Putco Jet yellow fogs.
mrtosh is offline
post #18 of 27 Old 09-29-2009, 10:28 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Good Luck...
I highly doubt they can program them unless you already have two working keys in which case you can do that yourself. Programming a key without two working keys requires a DRBIII scan tool.
~James
ezflip is offline
post #19 of 27 Old 09-29-2009, 11:19 AM
Redrum_1
You never know till you try. My hardware here is an Ace Hardware. They been in business for 70 years and try to keep up to date on things. I know they have the correct transponder blanks for my 2000 WJ and he looked in his book and said he could program them also.
Good Luck...
Redrum_1 is offline
post #20 of 27 Old 09-29-2009, 11:34 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Good Luck...
The keys are hard programmed meaning you cannot change them. Each key has a unique RFID signal it transmits. To program it to work with your jeep, nothing is actually done to the key itself. It is all done via the module in the jeep. Using the DRBIII tool, the dealer tells the jeep to be ready for new programming at which time they insert the new key and the module accepts the new RFID signal from the key and remembers it for future use. So no, the hardware store cannot program them.
It is like pairing a bluetooth headset to your cell phone. You have to tell your cell phone to accept a new device. If anyone could program their headset to any phone, there would be a lot of eavesdropping going on. You have to tell the main device when to accept a signal from the secondary device. In this case, the jeep is the primary device accepting a new signal from the secondary device (the key)
But, by all means, if you want to take your key into ACE hardware to see if they can program it, be my guest.
~James
ezflip is offline
post #21 of 27 Old 09-29-2009, 12:36 PM
Redrum_1
Everything you wanted to know about WJ Jeep keys but were afraid to ask!
Jeep Grand Cherokee WJ - Sentry key programming
Good Luck...
Redrum_1 is offline
post #22 of 27 Old 09-29-2009, 12:51 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Thats too funny. Getting a SKIS key programmed at Ace Hardaware? Thats like bringing your Fedex package to the Wendys drive thru.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #23 of 27 Old 09-29-2009, 12:53 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Whos the funny guy now?
~James
ezflip is offline
post #24 of 27 Old 11-05-2009, 08:12 AM
marioct
2007 WK
Now that is thinking! glad we have smart people on here. I was thinking of a way around this system for a remote start.
Does this system(sentury), actually stop a theft if some idiot decides to bash my steering column in?
marioct is offline
post #25 of 27 Old 11-05-2009, 09:04 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Well, that idiot can still steel all your ****, but hes not going anywhere with the jeep itself, unless he puts it on his back and runs away with it
Some of your better (more expensive) remote starts will be programmed with the info from the key then have a wire that wraps around the SKIM in the Jeep to make it think it is being started with the correct key. Some of the cheaper remote starts will just take a spare (programmed) SKIS key and zip tie it to the dash, which kind of defeats the whole purpose of the SKIS. At least with the better remote starts, it doesn't send the signal to the SKIM unless it is told to do so via you pushing the button on the fob.
~James
ezflip is offline
post #26 of 27 Old 11-05-2009, 09:31 AM
JesseOR
That is an interesting description of how remote start works and the opposite of my understanding....
The comp is told to start by the key fob, it will stay running for a period of time if you do nothing. If someone tries to get in and take it, as soon as it is taken out of park w/o a key in the ignition or in the vehicle the ASD will shut it off. The whole "zip-tied TP key" had me lMFAO.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #27 of 27 Old 11-05-2009, 09:57 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
This is correct once the Jeep is started. However, the Jeep cannot and will not start without the proper RFID signal, whether that signal comes from the remote start unit itself, or from a programmed key zip tied to the dash. Oh, and the ASD relay is usually linked to the brake pedal, not to the shifter
~James
ezflip is offline
jeep starts then dies ghost4570 WK Grand Cherokee & XK Commander Forum 5 03-25-2009 07:42 AM
Uh OH! Big problem! jeep dies! ZJcrawler45 ZJ Grand Cherokee Forum 5 12-24-2008 03:20 PM
Rough Idle / Dies when changing gears / Dies in low RPM's only MFS_WJ ZJ Grand Cherokee Forum 3 09-02-2007 02:18 PM
jeep idles down and dies freeburg ZJ Grand Cherokee Forum 3 02-08-2007 09:36 PM
Jeep just dies boatbum ZJ Grand Cherokee Forum 5 03-02-2005 10:55 AM
