Tried Everything - Still rough idle... 4.0L WJ - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Tried Everything - Still rough idle... 4.0L WJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Memorial Day Sale at Under Cover Fabworks! 15% Discount o
Unread 08-26-2008, 03:31 PM   #16
Intense-Dakota
I put the original NGK V-grove plugs in (the factory service manual says .040 for the 2004 4.0L, but the sticker under the hood .035.... so I did the .040).
Intense-Dakota is offline   Reply With Quote
Unread 08-28-2008, 11:40 PM   #17
the88thpianoman
the88thpianoman's Avatar
2003 WJ
I've been having the EXACT same problem. I was about to say except for the stalling, but I actually did stall while moving at an idle the other morning. The pulsing rough idle I've been experiencing for a while, though. I dumped a quarter tank of 89 octane in there earlier tonight, and so far, it seems to be running perfectly smooth. I'm not suggesting this as a solution per say, but maybe this could help us both narrow down what the problem is? Granted I haven't replaced my TPS or IAC, but I have fresh plugs, fuel filter, clean TB/IAC, and I've run lucas in the tank and mopar CCC. The lucas seemed to help slightly and briefly, nothing else seemed to make any difference at all, except for using the higher octane.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
