Trasfer case information needed. - JeepForum.com
post #1 of 5 Old 07-25-2003, 06:01 PM Thread Starter
toddvin
Hi guys,
What can anyone tell me about the transfer case on a 94 grand cherokee that only has the 2wd, 4wd pt, and 4wd lo options
(no 4wd full time option). Im stongly considering purchasing this vehicle and would greatly appreciate any input.
BTW it is a 94 with 120,000mile, 4.0, and very clean and they are asking $5500
What do you think?
Thanks a lot.
TV
toddvin is offline
post #2 of 5 Old 07-25-2003, 11:48 PM
EricsXJ
The Post man
EricsXJ's Avatar
That sounds like the NP231 transfer case that is very common in the Cherokees (XJs) It is very similar to the NP242 which has the full-time option. The 231 is a little stronger but they are both aluminum case, chain driven transfer cases. Basically with part-time, the rule is never use it on dry pavement, or even just wet pavement. Only use it offroad or on-road when the road is snow/ice covered.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #3 of 5 Old 07-26-2003, 05:31 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
tod,
check the servicing on it. Check the engine and suspension components. If you like it, it sounds pretty good.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 5 Old 07-27-2003, 07:18 AM
PDshooter
If you look at the "Transfer case "there should be a tag on it and will have the info you need!
PDshooter is offline
post #5 of 5 Old 07-27-2003, 07:27 AM
Swamp Boy
Swamp Boy's Avatar
I agree with Eric it sounds like a 231 and that would make it a nice package... As long as its mechanically and electrically sound...
Make sure everything works and if you like it buy it.. Sounds like a good deal..
Just another soccer moms Grocery getter....
Swamp Boy is offline
PCM Engine module information needed klockdoc ZJ Grand Cherokee Forum 32 03-31-2009 09:18 AM
Trasfer case leak, I think... 3856qpzd ZJ Grand Cherokee Forum 2 07-10-2008 10:08 AM
93 zj trasfer case aw4 trans milkman1563 ZJ Grand Cherokee Forum 2 06-07-2007 07:54 PM
Trasfer Case Input Shaft Swap CrawfishStu ZJ Grand Cherokee Forum 2 11-28-2006 09:16 PM
Trasfer case leak TriggerHappy ZJ Grand Cherokee Forum 3 03-15-2006 05:13 PM
