transmission wont shift into second - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > transmission wont shift into second
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 01-15-2008, 04:23 PM   #1
LBX2G
I was haveing a lovely day until my transmission started to act up. I was on my way to pay a bill when the transmisson would not shift in to second gear. So I pulled over for a second to check the fluid. The fluid level was fine. So I tried to continue my journey to pay the bill. It did the samething. So I pulled over again. This time I just shut the car off. Then I fired it back up. Then from there on it has been shifting fine. I mean wonderful. It shifts as if was a brand new car. Can someone explain to me what happened and if I should be looking for a new transmission.
p.s. My brother has been driving car lately and he said he has accidently been driving it is 2 gear. I mean he just does it for a tittle while.
*******************Disclaimer*****************************
when I make a post. I am only posting my opioion and my experince and what I have learned from it. I am not claiming to be no kind of all knowing god. I am not trying to shove my work or my experince into no ones face. If it helps you in anyway then you are welcomed if it does not....well sorry that I can not be of somekind of assistance.
LBX2G is offline   Reply With Quote
Unread 01-15-2008, 05:02 PM   #2
DTrem08
Your a lucky one. You should be able to manually shift from 1st > 2nd> drive.
Mines similar, but only does it from 3>4...and only in the first 20 minutes of a ride on a cold day. lol
Ive heard the tranny's are real picky about having JUST the right amount of fluid, if its a little low, you get problems like said
**LOOKING FOR MY JEEP, LAST SEEN IN CT and CURRENTLY HAS CT PLATES
White 1996 Grand Cherokee Laredo, I6 4.0 20% tint all around
**KOR Radiator Support, IRO 3.5" lift, 31/10.5/15" Maxxis Bighorns on 15x8 Cragar Soft 8's, JKS Bar Pin Eliminators, KOR Light Bar, 4 Black KC HiLites, Flowmaster Super 44 with turndown/no tailpipe, OME Steering Stabilizer, Black KOR square rock sliders
**If youve seen it around CT or know about it, PM me
DTrem08 is offline   Reply With Quote
Unread 01-15-2008, 07:56 PM   #3
LBX2G
so are u saying that i am good to go.
