Transmission won't shift into OD until engine is warm? - JeepForum.com
post #1 of 5 Old 12-05-2007, 05:20 AM Thread Starter
GDITheman
I have a 2004 Grand Cherokee Laredo with the 4.0. Now that it's cold, the transmission won't shift into overdrive until the engine is completely warmed up and then it just shifts into OD as I'm drivign down the road.
It has 68,000 miles so maybe it's time for a tranny fluid change. Will that help or is there something else I need to look for?
Thanks.
GDITheman is offline
post #2 of 5 Old 12-05-2007, 06:52 AM
ezrider327
Not knowing "exactly" what trans you have I am kind of guessing, BUT I believe this is actually normal. Most electric od transmissions will prevent the OD from coming on until the trans is at a certain operating temp.
As long as it works fine after she is warmed up I wouldn't be worried about it.
At 68,000 I would do a fluid change anyways, don't think it will help, but it surely won't hurt.
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!! ESSAYONS
97 F350 Dually CC Powerstroke- - 65 Mustang - 74 Super Beetle - 93 Harley Sportster
97 ZJ 4.0 4x4 Auto : Rusty's BB lift & Rusty's K&N intake
235 75 15 Toyo Open Contry AT's 15x8.5 Eagle alloy's
Flowmaster exhaust, custom winch bumper, Ramsey 9000lb, THULE MOAB roof rack
ezrider327 is offline
post #3 of 5 Old 12-05-2007, 06:53 AM
Turbonut
According to the AFM, the torque converter will only lock up after vehicle is warmed up. So I assume that it is in OD, but the drop in RPM's is the locking of the converter, not the trans shifting. Give it a try and see how many times the trans actually shifts when cold to see if it is really in O/D waiting for the converter to lock up.
The V-8's with the 545 will not shift into fifth until the trans is at a certain temp.
Turbonut is offline
post #4 of 5 Old 12-05-2007, 07:09 AM Thread Starter
GDITheman
It shifts fine but doesn't go into OD. Sounds like this is normal until the tranny fluid is warm. Just odd. I've had a few Jeeps over the years and never had this happen. It started when the temps dropped below 20 deg. So I guess it all makes sense.
I didn't know if switching to a synthetic oil would help with this. Sounds like it may not if a temp sensor decides when it's shifts into OD.
Thanks for the info.
post #5 of 5 Old 12-05-2007, 07:20 AM
PSUHunter
I have a 00 Grand with the 4.7 and mine will not shift in OD until it is warm. One day when it got cold I was driving it and got worried, but then it shifted into OD, and it does it every morning when I leave for work, so I assume its the norm
PSUHunter is offline
Rough Idle / WARM engine WJ 4.0 KaiTTown ZJ Grand Cherokee Forum 15 02-27-2013 04:36 PM
5.2L Engine Tapping/Knocking after Warm Up hann300 ZJ Grand Cherokee Forum 10 08-16-2012 05:36 PM
4.0 Ruff Idle When Engine Warm dave3275 WK Grand Cherokee & XK Commander Forum 1 07-22-2008 02:41 PM
95 GC Wont Shift Out of First Gear When Warm Gizimomo86 ZJ Grand Cherokee Forum 5 12-12-2007 06:22 AM
warm tranny shift issues 580z ZJ Grand Cherokee Forum 2 10-30-2007 06:47 PM
