Transmission slips only in drive... - JeepForum.com
post #1 of 5 Old 06-22-2009, 12:46 AM Thread Starter
CMARJEEP
CMARJEEP's Avatar
My transmission just all of a sudden started acting weird. From a stop, when I step on the gas, it acts like a manual transmission with the clutch let out only half way. Its like the transmission isn't grabbing all the way or something. Once I get going a little faster, it will shift fine and doesn't have the problem. Another way to explain it is like the brakes are being applied a little or something is 'holding it back'.
Now, when I manually put it in 1st gear it acts completely normal and doesn't have the problem.
I'm thinking its something with the linkage possibly. Just wanted some ideas of what it might be before I take it in. Thanks.
CMARJEEP is offline
post #2 of 5 Old 06-22-2009, 12:09 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
sounds like you don't have first gear. get it scanned, possibly tranny speed sensor related.
ratmonkey is offline
post #3 of 5 Old 06-22-2009, 01:29 PM Thread Starter
CMARJEEP
CMARJEEP's Avatar
But I do because when I put it into the actual "1" position it drives just fine. But when I put it in drive it does the whole slipping thing.
CMARJEEP is offline
post #4 of 5 Old 06-22-2009, 04:12 PM Thread Starter
CMARJEEP
CMARJEEP's Avatar
Took it in today. Ended up being the governor and transducer. The reason it felt like the brakes were being applied was because it was starting out in 3rd gear so it was bogging down. Cost $350 including fluid and filter change.
CMARJEEP is offline
post #5 of 5 Old 06-22-2009, 05:55 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
manual one uses different fluid pathways to engage first and second gear than in d.
Transmission sometimes slips when going into Drive or reverse? crmaverick ZJ Grand Cherokee Forum 6 02-08-2012 01:00 PM
Transmission slips in Drive, but drives fine 2nd mobrien006 ZJ Grand Cherokee Forum 0 01-07-2010 11:08 PM
transmission slips macwig52 ZJ Grand Cherokee Forum 0 04-21-2009 08:10 PM
Transmission Slips Bocyfus ZJ Grand Cherokee Forum 12 01-27-2005 07:57 PM
What exactly is it when the transmission slips? Zeitgeist ZJ Grand Cherokee Forum 7 06-28-2004 02:09 PM
