Transmission Slips - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Transmission Slips
Component speaker deal for your dash - NalinMFGJK Vent Covers - NalinMFGTJ 5.25" Speaker Adapters - NalinMFG
Unread 07-31-2014, 04:12 PM   #1
tj2kj
Transmission Slips
Question about my Auto Transmission on my 98 ZJ 4X4 (with NP242 xfer case). When I first cold start the car and put in gear it is like the torque converter is slipping. Takes a few seconds until it locks up and the car is moving correctly. Also notice sometimes when it shifts it goes loose between gears (revs shoot up, then it engages next gear). This happens only sometimes and can when it is shifting itself or I am manually shifting. Vehicle has about 190k miles.
Any ideas on the issue?
Is there a better trans that can be easily swapped in (maybe with more gears) or is this one the one to have?
Thanks...
tj2kj is offline   Reply With Quote
Unread 07-31-2014, 04:54 PM   #2
JohnnyV
Have you checked the trans fluid level, dropped the pan and replaced the filter, add new fluid? How's the transfer case's fluid level. When was the last time it was changed?
2002 WJ Limited 4.7L
1995 ZJ Laredo 4.0L
1989 XJ Laredo 4.0L - Sold
JohnnyV is online now   Reply With Quote
Unread 08-01-2014, 08:34 AM   #3
tj2kj
Fluid level is fine and it looks good in color. It has been a little while since changed (filter & fluid). I was thinking that might help.
