Transmission service ?'s - JeepForum.com
post #1 of 15 Old 06-05-2013, 09:13 AM Thread Starter
unabashedpraise
Issue: Never had the transmission serviced since I bought it 50k Mikes and 4 years ago. At highway speeds while coasting it will sometimes drop rpms (from 2k to 1k)and when I tap the gas they will shoot back up.
Bought a filter and gasket from rockauto to do my own fluid change. Now I'm thinking I should get a flush and have a professional do the band adjusting. I have only looked at the inside of a transmission twice and don't know what to look for other than obvious broken pieces sitting in the pan. How much should this run me? When i called the two local places they rather emphatically said they would not use my filter. I completely understand why they won't, however I didn't appreciate their rudeness and I don't want to waste this filter. Not sure what to do at this point.
1998 Grand Cherokee Limited; 5.2 L, 249
Help: Rear left lock doesn't lock using power locks, but will unlock. Any ideas?
unabashedpraise is offline
post #2 of 15 Old 06-05-2013, 09:55 AM
PolkaPower
Don't flush an old transmission. It could make it much worse. I would take it someplace they aren't rude. It's your money if they don't want it then they can eff off.
PolkaPower is offline
post #3 of 15 Old 06-05-2013, 05:35 PM
capcyclone
capcyclone's Avatar
What Polka said. Plus, maybe I'm lucky, but I take my ZJ to a shop occassionally for work I'm uncomfortable tackling myself (or when I have something I want/need done and I don't have the time) - and they have no problem using parts I already have. I don't see any reason you can't find a shop that will use the filter you have (not that a filter is that much $$$).
"The Jeep is America's only real sports car" - Enzo Ferrari
'98 Jeep GC 5.2L "ZJ" - Sold
'02 Jeep GC 4.7L HO "WJ" - Daily driver
capcyclone is offline
post #4 of 15 Old 07-09-2013, 04:39 PM Thread Starter
unabashedpraise
Found a shop, Cottman's, that said my filter was great, but would not use the gasket because it was crap. Go figure.
I went in with these symptoms:
-rpms drop while coasting at highway speeds (intermittently), tap on the throttle and they jump back up.
-doesn't shift from 1st to 2nd at full throttle.
Findings:
-They said it was 2 quarts over filled...? I checked it while warm and in neutral on level ground. Idk...
-They couldn't duplicate any symptoms.
- Pulled pan and said it looked "beautiful", no issues observed. Only thing to do is take it apart, but he said he didn't feel right doing it because there was no evidence to show that it needs it.
-engine and trans mounts broken, need replaced.
I went ahead and had them replace the mounts as I was not going to have the time before we leave.
First thing I noticed when I left the shop was that I really felt it when I shifted into reverse. Not hard or anything, but I never felt it before. Also noticed more vibrations than before and it feels like it is shifting a little harder. Not much, but just enough that I notice it. I've been paying a lot of attention to it the past couple weeks so I feel like I'm not any more sensitive to it now than before. I'm sure the mints have a break in period, but wasn't sure if they adjusted things too much.
Also, while I haven't had time to do any highway cruising for the rpm drop, the not shifting from 1st to 2nd symptom was replicated with no problem...it wasn't fixed. Here is a bad video that shows the rpm needle hitting relive and not shifting.
https://www.youtube.com/watch?v=18Wz...e_gdata_player
At this point I'm not even sure this is a trans issue at all, but I did just spend $600 and want to know if it should have been covered. Thoughts?
post #5 of 15 Old 07-09-2013, 07:26 PM
Kevinyj95
HS batman. Did you try to adjust your cables? You did make sure they put in atf+4 correct? Some places use a universal fluid that ruins jeeps transmissions. Always ask. Always use ATF+4 for Chrysler vehicles. Or Mopar. Lucas might help. Some one disagree. But Ive always used it in cars with high miles. never add it to a ford. Or a t5 or t15. 42re-46 are good. I believe the hard shifting etc may be the band adjustment. But the shifting rpms are not good. check out the cable adjustments. If this was a newer dodge I would tell you to check the input output sensors. I never bring my car to other people you just cant trust them. You never know they could have over torqued it.... I figure if I make a mistake I will atleast know about it and be able to figure it out with out ripping everything apart. But some mechanics have skills. But finding a good one is hard. Most of the time there always that person trying to rush through and ends up messing something up. Or has some one else do the job because they don't want to. Torque converter worst case. I doubt it though.
Kevinyj95 is offline
post #6 of 15 Old 07-09-2013, 09:36 PM Thread Starter
unabashedpraise
I didn't do any adjustments. I don't know what fluid they used. The owner does have a 95 zj, 5.2 that he says has 360k. So I would hope he knew what it needed....?
I was hoping for some ideas/info to bring to the guy so I'm not just another customer without a clue.
post #7 of 15 Old 07-10-2013, 01:02 AM Thread Starter
unabashedpraise
Also, I have another thread about my wobbling harmonic balancer no longer wobbling, but the engine is shaking. It's this the balancer? Something else? It used to be smooooth as buuuuuutter.
post #8 of 15 Old 07-10-2013, 11:20 AM
Kevinyj95
Well..... the sleeve on the balancer maybe most likely not. How are the engine mounts? Did you replace the engine mounts with a different brand. In my mustang I had polys and I switched. It was like riding on a washing machine. Other than that I would say make sure your not miss firing etc.. Warped crank maybe hope not and I haven't seen it in jeeps. But I have seen it in other cars. Hows the oil pressure? I would look up the write up for adjusting the cables. Before going any further with the transmission. My engine shakes a little. Oddly enough my 5.2 shakes more than my 5.9. Check the trans mount too.
post #9 of 15 Old 07-24-2013, 08:56 PM Thread Starter
unabashedpraise
Shaking was a misfire in #7. All is well now.
post #10 of 15 Old 07-24-2013, 09:18 PM
newfieZJ
They didn't adjust your bands at the shop ?
Adjust your throttle/shift cable on the pass side of the TB . Would have been nice if they did the bands . Only other issues I know to cause this is bad sticking cable or governor pressure switch
newfieZJ is offline
post #11 of 15 Old 07-24-2013, 09:29 PM Thread Starter
unabashedpraise
They adjusted bands and tinkered with the kick down cable, but any adjustment was bad. Gov switch is next suspect but service manager stated it was a bit expensive. Only other recourse was a rebuild.
Just got back from a 2200 mile road/wheeling trip, transmission did just fine, no issues. I just have to careful if I'm punching it while in first.
post #12 of 15 Old 07-24-2013, 09:42 PM
newfieZJ
There's a kit you can buy with 2-3 sensors/solonoid (incl. gov press.)and a new accumulator spring for under $200 IIRC .
Just the switch alone is cheaper http://www.partsgeek.com/ss/?make=Do...y=Transmission
newfieZJ is offline
post #13 of 15 Old 07-24-2013, 09:46 PM Thread Starter
unabashedpraise
Thanks, I'll keep this in mind. Unfortunately, the $ drop on the mounts and the vacation pretty much takes that option out of play. Good to know though.
post #14 of 15 Old 07-24-2013, 09:51 PM
newfieZJ
And I agree . You may as well drive it for 6 months-2 yrs before dropping the pan again . So you also know , you can install a drain plug (B&M) on the stock pan . Makes oil changes and maintenance a lot easier to get past the work of dropping the pan . I have them on everything I own after the pan drops first time .
newfieZJ is offline
post #15 of 15 Old 07-24-2013, 10:12 PM Thread Starter
unabashedpraise
Now why haven't I thought of that?! Genius!
