Transmission Question for new guy - JeepForum.com
post #1 of 8 Old 11-26-2003, 01:27 PM Thread Starter
JoshR
Since I'm new here, I have several questions, but I was wondering about when the car is sitting and idling high because it i.s cold, and the brakes are on, it seems like something will engage off and on. Is that the torque converter?? Is that normal?
The fluid is still red, but is probably about due to be changed since we just bought this 97 GC w/ 138k, I'm not sure about trannie service history. They maintained the oil well though.
Since it is a 4 x 4 can Valvoline do a trannie service, or should it be done at the dealer only. Anything to watch out for?
What about differential service?? Is that really important too?
What about the VC? Is that a problem on these? Anything to watch out for?
Thanks. All input is appreciated!!!
JoshR is offline
post #2 of 8 Old 11-26-2003, 04:31 PM
Stocker
Congratulations and welcome!
First, only thing I can think of that will cycle is the A/C compressor. Like most if not all modern vehicles, it's designed that way to keep the seals in good working order, and it also helps dry the air so the defroster works better.
You'll likely pay more for the dealer to service the tranny, and any shop can do it, but check around. ATF+3 or the newer ATF+4 is advised, and change the t-case fluid at the same time. It might help your VC last longer. When they fail, the drivetrain binds up in tight turns at low speeds, especially when cold.
With 138K on the clock, I'd change diff fluid also - use dino or synthetic (I think 75W90 is called for), but if you have the tow package, be sure to use synthetic in the rear - and add friction modifier if you have trac-lok rear diff.
Check your owners manual for other service items, such as coolant, belts & hoses, air & fuel filters, plugs, wires, cap, rotor, brake pads...
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #3 of 8 Old 11-26-2003, 04:54 PM
Bob K
Bob K's Avatar
I just bought a WJ with 64k on the clock. I had the transmission serviced at a transmission shop. They changed the fluid, gasket and filter. Inspected it while they were in there. Test drove before and after.
This is the first auto trans I've ever owned and a lot of people say the GC trans don't last. So I don't want to take any chances. The tech who did the job recommends change and service every 30k miles. I think it's worth it.
The axles are an easy DIY. I use synthetic.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #4 of 8 Old 11-27-2003, 09:26 AM
Harald
What the other guys has brought forward here is very true. With 138K, your VC is statistically likely to die within short if it hasn't been replaced already. That is one days work by a professional to replace it. Caltex has a special oil for our lock up rear differentilals with additives included. Changing oil and filter on tranny and oil on transfer and diff's is not a big deal. If you are interested in doing things yourself, a Chilton or Haynes manual is recommended.
Harald is offline
post #5 of 8 Old 11-28-2003, 09:42 AM Thread Starter
JoshR
What is the viscous coupler (VC) and what does it cost to repair? Is it something that gives certain warning characteristics first before going out, and is it better to repair it before going out or does it matter?
Is this service something that can be done by a regular mechanic or by a transmission shop, or is it definitely a dealer service job?
Does remanufactured work fine, or is OEM the best idea for the parts?
(97 Jeep Grand Cherokee 6Cyl. 4x4 w/138k)
JoshR is offline
post #6 of 8 Old 11-28-2003, 09:58 AM
Stocker
The VC is the unit in the t-case that allows the wheels to rotate at different rates so that the driveline doesn't bind up during tight turns at low speeds. As to repair costs, I haven't had it done but it's fairly expensive; try using the search button for more info. I don't think there's any real warning; and the best thing you can do is routine maintenance (fluid changes).
Stocker
Stocker is offline
post #7 of 8 Old 11-28-2003, 10:58 AM Thread Starter
JoshR
Since I'm a fairly new first time Jeep Owner, can someone explain what the difference between the various models. I assume the WJ is the Wrangler...but when was the Jeep Cherokee first made, and what is the difference between the Cherokee and the Grand Cherokee, (does the Grand have the 4x4 capability?) When did the Grand Cherokee (I have a 97 turn into the new body styling) was it after the 98 model year?) Do people just refer to the Grand Cherokee as a GC?
JoshR is offline
post #8 of 8 Old 11-28-2003, 01:40 PM
Stocker
Cherokee is no longer made - it was phased out & replaced with the Liberty. Grand Cherokees are larger & can have V8 engines. GC is okay, but 93-98s are ZJ models, and 99+ are WJs (and have different body style). There are some 4x2 Jeeps, but most including Grands have 4WD or AWD.
Stocker
Stocker is offline
WJ Transmission Question BlackSS ZJ Grand Cherokee Forum 5 08-13-2009 01:17 AM
Transmission Question frankie_b11 ZJ Grand Cherokee Forum 3 08-11-2009 12:11 PM
Transmission question jimkrimmefr ZJ Grand Cherokee Forum 3 05-26-2008 09:20 AM
Transmission Question swataz ZJ Grand Cherokee Forum 7 01-19-2008 11:17 AM
transmission question again?!?! crazynut52 ZJ Grand Cherokee Forum 1 02-08-2003 04:31 PM
